- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Inter VLAN Routing on SRX5308
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have set up 2 different VLAN's on our SRX5308. I have checked the boxes for Inter-VLAN routing, but I can't access a compluter on the a VLAN different to the one I am on.
How is this possible?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Inter VLAN Routing on SRX5308
Hello JamesDunn,
Welcome to the community!
Are you using a switch behind the SRX5308? I would check the port where the devices are plugged in, make sure it is properly defined when adding a VLAN Profile. See this example. If you could also post a diagram of your network, it will be helpful.
Looking forward to your response.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi JohnRo,
we are using the Prosafe JGS524 switch. I've just googled this and it appears it doesn't support VLANs.
I assume there are no options left then unless we replace the switch?
James
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello James,
Yes, you'll need at least a layer 2 switch or 2 unmanaged ones. Please check our Smart Managed Switches series.
Thanks,
