Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Multihome FVS318N
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-10
09:45 AM
2012-06-10
09:45 AM
Multihome FVS318N
Hi all,
I have to connect my lan, LAN-01, to another, LAN-02, that is physically close to mine but separate. the two lan have different gateway/dns/Internet-WAN connection.
I would connect the two LAN with my Firewall FVS318n, so I could view LAN-02's PCs from my lan.
Current Set up
LAN-01
Subnet ID: 192.168.1.0
Mask: 255.255.255.0
firewall FVS318n:
PCs are in DHCP: from IP: 192.168.1.10 to 192.168.1.254
LAN-02
Subnet ID: 10.105.34.0
Mask: 255.255.255.0
IP gateway: 10.105.34.1
Pc's are not in DHCP:
IP FVS318n: 10.105.34.5
My issue
Both with vlan-intervlan configuration and with multihome configuration:
I can ping from ex. 192.168.1.101 to only 10.105.34.5 (my FVS318n) but not entire LAn-02's subnet 10.105.34.0.
I can ping from FVS318n to entire subnet 10.105.34.0.
Even if FVS318 is my gateway, do I perhaps need a static route on my workstations?
Any suggestions are appreciated.
best regards
ulis
Current Set up
LAN-01
Mask: 255.255.255.0
firewall FVS318n:
IP address: 192.168.1.1 (FVS318n is the gateway for my LAN-01)
IP WAN: 192.168.10.2 (connected to a modem router for WAN/internet connection)
LAN-02
Mask: 255.255.255.0
My issue
best regards
ulis
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-10
04:20 PM
2012-06-10
04:20 PM
Re: Multihome FVS318N
did you look Vlan rules just like in/out bound rules there should be one.
I know my prosecure UTM has that option other than specify the VLAN ID, DHCP, inter VLAN options
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-13
02:09 PM
2012-06-13
02:09 PM
Sorry for my late reply and
Thank you for your suggestion
but No rules for vlans in FVS318n
only for LAN/WAN LAN/DMZ WAN/DMZ.
I controlled also the route and seems ok.
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
127.0.0.1 127.0.0.1 255.255.255.255 UGH 1 0 0 lo
10.105.34.0 0.0.0.0 255.255.255.0 U 0 0 0 bdg2
10.105.34.0 10.105.34.5 255.255.255.0 UG 1 0 0 bdg2
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 bdg1
192.168.1.0 192.168.1.1 255.255.255.0 UG 1 0 0 bdg1
192.168.10.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
192.168.10.0 192.168.10.2 255.255.255.0 UG 1 0 0 eth1
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 192.168.10.1 0.0.0.0 UG 0 0 0 eth1
Any other suggestions are welcome
Message 3 of 3
