- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear SSL VPN maximum limit on number of active tunnels has been reached on netgear vpn
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have a working SSL VPN setup and has been for some time now. Is there any way to clear active tunnels from the admin without having to do a power off reset? I tried a software reset first but that did not clear the problem. Also, the geardomain admin has always been sluggish but now seems even slower than usual, I have to wait 8 or 10 seconds for a response any time I click.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear SSL VPN maximum limit on number of active tunnels has been reached on netgear vpn
Hello,
Welcome to the community!
To clear active tunnels,can go to VPN->Connection Status->SSL VPN Connection Status,click Disconnect button.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I tried that but no connections were showing to disconnect. I did find out the user was not closing the VPN properly after his remote control session timed-out or concluded; so he was admonished & re-educated on that. A power-off cycle of the SRX5308 cleared the error and the slow response times - crude but effective - though not ideal during the day when internet & email are being used by the staff.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi tkershaw,
Thanks very much for your feedback.
I tried to do the case, but didn't see the issue.After click "Disconnect" button,the user record will disappear.
How much users did you connect?
Thanks,
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Generally only one user logs in using SSL connection. He was not closing the tunnel properly; though the Netgear router should have timed-out and closed the tunnel unless he re-established a new tunnel right away... I had to power cycle the router to clear the improperly active tunnels that no-one was using.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi tkershaw,
I tried it according to your description.If the ssl vpn timeout or do not closing the tunnel properly.
The ssl vpn user will disappear automation under SSL VPN Connection Status page.
Which brower do you use?Which version of SRX5308 do you use?
Thanks,
Dan
