- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with SSLVPN connection to FVS336G v2 - firmware version 4.3.3-6
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I'm getting a client-side error of "Error in Connection Parameters! Netgear-SSLVPN-Tunnel Connection Aborted." when accessing the FVS336GV2 from both 32 bit internet explorer 8 and explorer 11.
The configuration of the router for SSL connectivity appears to be correct
Hoping that someone can help me with this!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Problem with SSLVPN connection to FVS336G v2 - firmware version 4.3.3-6
Hi joshdotreynolds,
Welcome to the community! 🙂
Kindly answer the questions below:
a. Were you able to connect via SSL-VPN just fine before?
b. Are there any changes made on the network where the FVS336Gv2 is deployed?
c. What Operating System(s) have you used so far?
d. Have you tried other PC(s) or laptop(s)?
e. What is the current firmware of the FVS336Gv2?
I look forward to your response.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks for getting back to me. I have supplied answers to the questions below.
Yes, - it works fine with firmware version 4.3.1.18 (I rolled back to this old version on one of my devices to confirm that it works).
None
Windows 7
Yes - I have used a number of machines (desktops/laptops) all running windows 7
4.3.3-6
JR
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi joshdotreynolds,
Can you try to install 64-bit IE11 on the Windows7-32bit PC then check if same problem happens. Use other PC(s) or laptop(s) if its necessary to isolate the problem.
DaneA
