- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SRX5308 - Firmware upgrade from 3.0.8-12 to v4.3.xx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there any way to upgrade from 3.0.8-12 to v4.3.xx with saving config? For example: backup 3.0.8-12 config and restore it after upgrading to 4.3.xx? Or I should manually tuning everything after upgrade?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi obtim,
Welcome to the community! 🙂
I'm afraid to inform you that it is not really possible to restore the configuration file from a v3.0.8-12 firmware to a v4.3.3.x firmware. You may just take screenshots of the settings on your SRX5308 while still on firmware v3.0.8-12 as a reference guide then reconfigure it from scratch after upgrading the firmware to v4.3.3.x. Be reminded that it is recommended to perform a factory reset on the SRX5308 after upgrading the firmware.
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi obtim,
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SRX5308 - Firmware upgrade from 3.0.8-12 to v4.3.xx
Hi obtim,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
