Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Vulnerability Scan - Port 23 Open
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-05
12:25 PM
2013-06-05
12:25 PM
According to the manual, the default Inbound rule is Block All; however, when I ran NMap TCP Connect Scan against the WAN IP, I was shocked to see some ports open. Does this mean that PCs in the same subnet can connect to my router?
Here's the result of the scan on WAN IP:
Now here's the result of the scan on the router's private IP that I assigned:
Then, I created a new Inbound rule to block access to Port 23 and the scan on WAN IP result is as follows:
Thanks for your help.
PORT STATE SERVICE
23/tcp open telnet
80/tcp open http
81/tcp open hosts2-ns
443/tcp open https
PORT STATE SERVICE
23/tcp open telnet
80/tcp open http
140/tcp filtered unknown
443/tcp open https
PORT STATE SERVICE
23/tcp filtered telnet
80/tcp open http
443/tcp open https
Message 1 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-05
01:01 PM
2013-06-05
01:01 PM
Re: Vulnerability Scan - Port 23 Open
I forgot to mention the model number and firmware version:
System Name: FVG318_NETGEAR
Firmware Version: v2.1.2-67N
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-05
02:26 PM
2013-06-05
02:26 PM
Where was the machine running the scan PHYSICALLY connected? If you scan the WAN ip address whilst physically connected to the LAN side of the firewall, you will get erroneous results.
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-05
03:27 PM
2013-06-05
03:27 PM
Go to GRC.com and run shieldsup
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-06
10:26 PM
2013-06-06
10:26 PM
Thanks, guys!
I'll run another set of test. I'll keep you posted.
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-09
09:18 AM
2013-06-09
09:18 AM
I ran another isolated test (not from the LAN side) and the result is the same. Standard port scanning will show no ports are open, but hen TCP connect scan was performed, ports 23, 443, 80 showed as open.
The worst part was I can telnet and access the Wewb administration page from the WAN side which makes it vulnerable for exploit.
Here's the same issue with another Netgear product:
http://www.cvedetails.com/cve/CVE-2012-2439/
I have to create an inbound rule to block incoming traffic for ports 23, 443, and 80 as a workaround.
I hope this will be addressed soon.
Message 6 of 6
