- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
2016 Teaming doesn't work with M4300-52 G
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I try to replace a old Netgear Switch (GS748Tv5) by a M4300-52 G. 2 switches are stacked. I have a Windows 2016 server (vlan 35).
The server is connected to the old switch through a teaming (see below the configuration - port 45 & 46)
LAG:
VLAN :
PVID:
Teaming conf on 2016
I try to connect the teaming to new server with the same configuration (see below the configuration - always port 45 & 46). The server seems to connect but i can't remote desktop on it (ping N_Ok). I try a reboot but same result.
LAG
PVID:
Any help will be appreciate. Thanks. Benoît
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
It's Ok now. I forgot the PVID on LAG1 on new switch. I found the solution on this community.
Thanks.
Benoît
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2016 Teaming doesn't work with M4300-52 G
Hi @Benoit72
Welcome to the community!
Could you please run below CLI command? We want to get more detailed info for analysis this problem.
show port-channel 1
show running-config interface lag 1
Beside, I notice the LAG type is static on old switch(GS748Tv5), so please make sure it's same config on new switch(M4300-52G).
Hope it helps!
EricZ
NETGEAR employee
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Thanks.
Benoît
