- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AXC763 SFP+ DAC CABLE with Intel X710
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there any known compatibly issue with the AXC763 SFP+ DAC CABLE and the Intel X710 Converged Adapter? I can't seem to get a link with this. I'm using a M4300-12X12F but have also tried directly connecting each port on the X170 without success. I also have Broadcom 57810 adapters that work fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AXC763 SFP+ DAC CABLE with Intel X710
Hi jg1
No there's no known compatibility issue with Intel® adapters.
I would advise to run latest 12.0.2.9 software on your M4300-12X12F, since we fixed some DAC issues with that release.
Can you upgrade your 12X12F first thing following the release note indications?
On a separate note, Intel® NICs usually require Intel SFP and SFP+ modules, they are locked or very picky like most servers / storage are (requiring same brand DACs).
That's the reason why we strive to support Third-Party DAC cables, as long as they are MSA standard. Another option could be, try the Intel® Ethernet SFP Twinaxial Cable 3 meters XDACBL3M and let us know how it goes with 12.0.2.9 latest software.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll get the firmware updated on the switches.
According to Intel the card should "support direct attach cables that comply with SFF-8431 v4.1 and SFF-8472 v10.4 specifications"
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006754.html
Thanks for the reply.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi jg1,
Welcome to Netgear Community!
I tried in my local environment. It's ok. I Connect M4300-12X12F to PC(Inter X710) with AXC 763 DAC Cable.
So I suggest you can update your Inter X710 adapter dirver and try again.
Below is the detailed information:
1. Switch fiber port info:
2.Inter X710 info:
Regards
Ericz
Netgear Employee
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was able to update the firmware on the M4300-12X12F but it had no effect. I'll look to update the x710 firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I updated the Firmware and Driver on the card and still no link. I switched the card to a Windows 2008 server and still no link. I'm not sure what else it could be besides the cable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
1) do you have more DAC763? Could you try another one?
2) Could you provide the output of 'show fiber-ports optics-info all'?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Port 10 is connected to the x710.
I've tried 3 different AXC763 cables with none working.
(M4300-12X12F) #show fiber-ports optics-info all
Link Link Nominal
Length Length Bit
50um 62.5um Rate
Port Vendor Name [m] [m] Serial Number Part Number [Mbps] Rev Compliance
1/0/1 NETGEAR 0 0 16092D0060 AXC761 10300 A DAC
1/0/2 NETGEAR 0 0 16142D0135 AXC761 10300 A DAC
1/0/3 NETGEAR 0 0 16142D0453 AXC761 10300 A DAC
1/0/4 NETGEAR 0 0 16092D0011 AXC761 10300 A DAC
1/0/5 NETGEAR 0 0 16092D0132 AXC761 10300 A DAC
1/0/6 NETGEAR 0 0 16142D0316 AXC761 10300 A DAC
1/0/7 NETGEAR 0 0 16142D0279 AXC761 10300 A DAC
1/0/8 NETGEAR 0 0 16142D0519 AXC761 10300 A DAC
1/0/10 NETGEAR 0 0 16191D0035 AXC763 10300 A DAC
- Mark as New
- Bookmark
- Subscribe
- Permalink
does it come up if you use AXC761 instead? and could you post the techsupport file too?
you can go to the GUI, maintenance->export->HTTP file export, select 'techsupport file' to get techsupport file.
