Orbi WiFi 7 RBE973
Reply
Blocking outgoing packages on a port
tik0
Tutor
Dear NETGEAR community,
I run the M4300-52G-PoE+ ProSAFE on the latest firmware version "12.0.11.13" in a very minimalistic configuration:
  • There exists only one VLAN 1 where all ports are assigned to (plus one configuration VLAN 2)
  • All features of the M4300 are turned off, so it actually acts as a common unmanaged switch
  • 3 devices are attached to VLAN 1
    • Port 50: Uplink
    • Port 14: PC1 (device with MAC address "22:A8:2E:21:CA:1C")
    • Port 3: PC2
My goal is as follows:
  • PC1 and PC2 are allowed to communicate
  • PC2 and Uplink are allowed to communicate
  • PC1 and Uplink are not allowed to communicate (Any package from PC1 may not leave Uplink)
My current approach:
I though of configuring an ACL as in the attached image. But as soon as I apply the rule, all communication over Uplink is blocked. Am I missing something or do I misuse ACL? It would be nice if some could clearify my issue or at least give a hint, how I can accomplish my goal.
Kind regards
Model: GSM4352PA|M4300-52G-PoE+ - 48x1G PoE+ Stackable Managed Switch with 2x10GBASE-T and 2xSFP+ (550W PSU)
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: Blocking outgoing packages on a port
@tik0,
Welcome to our community! 🙂
Using ACL where the PC 1 is connected should be configured. You may check it here on how to use ACL.
John
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 611 views
  • 0 kudos
  • 2 in conversation
Announcements
