AlanWillemssen
May 15, 2018Follower
Enable https / Disable http on GS728TP
I need to know how to enable https and disable http on a Netgear GS728TP switch. If http cannot be disable, how to I automatically forward it to an https connection?
Any help is appreciated.
- JohnC_VNETGEAR Employee Retired
Hi AlanWillemssen,
Welcome to our community! :)
Secure HTTP enables the transmission of HTTP over an encrypted Secure Sockets Layer (SSL) or Transport Layer Security (TLS) connection. When you manage the switch by using a web interface, secure HTTP can help ensure that communication between the management system and the switch is protected from eavesdroppers and man-in-the-middle attacks.
Here is the manual on how to setup the HTTPs management (page 171) and then manually set a port forwarding to your firewall/router.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
