Retired_Member
Feb 21, 2022Enabling DHCP reservations on M4250
Hi all,
I am trying to add a couple of MAC address to a DHCP reservations list through the management Web UI of my M4250. I have already set up a DHCP pool and had the server assign IP's, now I want to move a couple of my NDI devices to maunally assigned an address within the DHCP server.
What I am doing is;
- Afrer setting up the DHCP pool
- I go into "DHCP Pool Config"
- Have my pool selected under "Pool Name"
- Change the "Type of Binding" field to "Manual"
- Enter all the required information, including the "Hardware Address" and "Client ID" (the MAC address with 01 at the front)
- Then hit "Apply"
- And then I get this error
- "Error! Fialed to Set 'Hardware Address' with xx:xx:xx Error! Failed to Set 'Client ID' with XX:xx:xx:xx Error: Could not set host because neither hardware address not client-identifer is configured. Please configure hardware address or client-identifier for host first"
Do I need to set the MAC address that I want to use somewhere else first, if so where? I can't find any information on this. I have definatlly set the hardware and client id fields because it reads them back to me in the error.
Hopefully someone here has an answer because I don't see why this should be this hard. Thanks in advance.
Dave K
- Retired_MemberMar 02, 2022
Hi, and thanks for your reply.
I have worked this out, with the help of one of your Pro AV team, and I was making a couple of mistakes. First, as you mentioned, I was adding these under the pool I was using for my main DHCP server, and not making a separate pool for each manual reservation I needed. Second, I hadn't cleared the dynamic reservations before I tried to make the manual ones.
I did end up doing all of this by using the CLI in the end using the following syntax.
service dhcp
ip dhcp pool "VLAN 200"
default-router 192.168.200.1
network 192.168.200.0 255.255.255.0
netbios-node-type b-node
exitip dhcp pool "Laptop"
hardware-address f8:75:a4:39:ad:de
host 192.168.200.10 255.255.255.0
exitip dhcp pool "Printer"
host 192.168.200.11 255.255.255.0
exitI will close this post.
Cheers,
Dave K
- JohnC_VNETGEAR Employee Retired
Hi HomerJayK,
Welcome to our community! :)
It seems that you are having problems adding a DHCP reservation on your switch. The MAC address that you want to use should be configured on the DHCP pool configuration after you created the pool. May I know the firmware version? If the switch is not running on the latest version, please do update the firmware first and re-do the configuration.
I hope this article might help too.
John
NETGEAR Community Team
- Retired_Member
service dhcp
Cheers,
Dave K
