MwrightCRS's avatar
MwrightCRS
Follower
Jan 11, 2018
FS728TP not passing DHCP
My Managed switch seems to not be passing dhcp to devices connected to it
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi MwrightCRS,
    Welcome to our community!
    It seems that you were having issues with the switch that you have. May I know if it is still providing power to POE? Can you still ping the switch? You may try resetting it first to factory default and upgrade the firmware to its latest version.
  • JohnC_V's avatar
    JohnC_V
    MwrightCRS,
    I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
