wodo's avatar
wodo
IGMP Snooping breaks Bonjour / AirPrint
Hi,
since we use a GS116Ev2 switch in our network we constantly had problem using AirPrint or other services that rely on Bonjour. Sometimes discovery of the AirPrint capable printers worked. Sometimes not.
I figured out that the IGMP Snooping option is the root of this problem. Once this option was disabled, everything worked stable.
Is Netgear aware of this problem? And will be a new firmware fixing this?
Thanks!
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi wodo,
    Welcome to the community! :)
    So far , I have not found any issues pertaining to IGMP Snooping that it breaks Bonjour/AirPrint when its enabled on the GS116Ev2.  Kindly answer the questions below:
    a. What is the current firmware version of your GS116Ev2?
    b. Does same problem occur if you remove the GS116Ev2 from your current network setup?
    c. Have you tried to perform a factory reset on the GS116Ev2 then reconfigure it from scratch and check if same problem occurs when IGMP Snooping is enabled?
    DaneA
    NETGEAR Community Team
    • wodo's avatar
      wodo
      Here are my answers:
      a.) 2.0.1.26
      b.) No. Without the Netgear the problem does not occur.
      c.) Yes. Factory Reset did not help.
      I have two AirPort Express connected to the Netgear. The AirPrint devices are connected to the WLANs of these AirPort Express. When the AirPort Express stations are rebooted, AirPrint works for a few minuten across the NetGear switch. But then the AirPrint devices start to disappear and are no longer discoverable across the GS116E.
      • DaneA's avatar
        DaneA
        Hi wodo,
        Can you try to downgrade the firmware to v2.0.1.24 then check if same problem will occur.  Be sure to perform a factory reset on the GS116Ev2 after a successful downgrade of the firmware then reconfigure it from scratch.
        DaneA
ProSupport for Business
