sramelyk's avatar
sramelyk
Novice
Apr 25, 2015
IP Routing problems
I have the 24 port m4100 layer 3 switch..
Port one, router enabled with the ip address of 192.168.1.201
Port six, router interface with the ip address of 162.114.69.16
I have a PC plugged in to port one, with the ip address of 192.168.1.1 its default gateway is 192.168.1.201.
From the 162 network, I can't get to the 192.168.1.1. If I do a tracert, it ends at 162.114.69.16.
There is a "Learned Route" entry of, 192.168.1.0 next hop 192.168.1.201.
I was thinking there needed to be a static route, but went to add it and the learned route was there.
What am I missing?
Thanks in advance!
Kyle
1 Reply
  • Do you enabled the routing mode?
    Its on Routing>IP>Routing mode Enable
ProSupport for Business
