rbizzell40
Dec 06, 2016Follower
Inter-vlan routing
My existing network is all on the native vlan of 1 not segmented at all. I have a new netgear 10G XS708T that I want to connect to network but create vlans for virtual machine traffic. This will be a totally separate network how do I configure the the vlans to route between the native vlan and other vlans. I understand how to configure the vlans but how will I configure the route to another network. My other switches are HP I have one uplink port connected the the native vlan that network 172.16.0.0 my and the network of the netgear switch has IP from the native vlan. The other vlans with be 192.168.10.0 192.192.168.20.0 etc my router is from the native network
1 Reply
- Carl_zNETGEAR Expert
Hi rbizzell40,
Welcome to Netgear Community!
You can refer to this,may be it is helpful .
Beside this, I think you also need to add some static route. You can take a routing vlan as a L3 physical interface,and routing between vlan just work as L3 ip interface.
Regards
Carl
Netgear Employee
