Budgie4's avatar
Budgie4
Tutor
May 18, 2020
M4100-D12G Managed Switch Bridged Pair with 3 subnets
Hi, I have 2 of the captioned switches working over a bridge link with Vlan trunking of 3 subnets.
All work well but, to date and for WiFi I have used a separate WiFi AP connected to the subnet port on the far side of the bridge.  I now need to use different SSIDs for each subnet working on the same AP.  The AP has the vlan capability but how do I connect all the subnets to the one AP?  Do I connect to the trunk traffic or should I set up the vlan configuration differently and how does DHCP work when all different AP clients require an IP from the respective subnets DHCP.
I hope this is clear and that you can help.
  • schumaku's avatar
    schumaku
    Typical solution is having dedicated VLANs for each IP subnet, and configure a VLAN trunk for the connection to the undefind Wireless AP, either run the primary VLAN and/or management VLAN [U]natgged and all other VLAN [T]agged, or configure all VLANs [T]agged.
    • Budgie4's avatar
      Budgie4
      Tutor
      Hi and thanks for the reply.  I already subnets and vlan trunking in place across the bridge with three subnets from the router vlanned into one M4100 to combine and serve the trunk connection and with the second M4100 receiving the trunk connection and splitting this to serve the three subnets at the far end.  The required AP is on the far end of the trunk.  I have two ports available and unconfigured on the switches.  Can I arrange for one of the spare ports on the far end M4100 to be a copy of the trunk connection?  Not sure if I am right and how may I proceed?  Is there an example I can follow please?
      • schumaku's avatar
        schumaku
        No copy or the like, the port for the AP must be configured as per your VLANs, and so does the AP. The AP does connect to a port configured similar to the trunking port, and the AP itself is configured like a trunking devices, too. The SSID<->VLAN association must be done on the wireless access point. The only thing you have to figure out is the AP configuration for the management VLAN, e.g. for UniFi it's untagged.
        x
    • Budgie4's avatar
      Budgie4
      Tutor
      I have it now thanks setting up a trunk for the port which feeds the AP. Will do this for all the rest.
      I did have a problem with the AP devices as L2 isolation had been set on all SSIDs.  My mistake but will nead to read up on configuring management VLan correctly for all devices so I can connect to all of them, switches, APs and Router.
      Is the correct practice to set up a management subnet and putting all devices to have static IPs on that subnet?
      Your guidancemuch appreciated, thanks again,
      Budgie4
ProSupport for Business
