- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
M4300 12x12 Problem speed with qnap 20Gb Lacp configured
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
I have problem with Netgear M4300 12x12 with Qnap TS-EC2480U R2 configured on each other 2 x 10Gb Lacp .
The link is up , but problem in speed.
when i copied from freenas (10gb + 10gb link aggregation configured) on qnap the speed is rate between 10mb/s to 100mb/s , and from my computer to qnap or freenas , the speed rate between 10mb/s to 100mb/s.
FreeNas is LAGNASE1
QNAP is NASGLB
where is the problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: M4300 12x12 Problem speed with qnap 20Gb Lacp configured
Welcome to the community! 🙂
Kindly answer the questions below:
a. What is the brand/model of the fiber modules you are using between the M4300-12X12F and the QNAP TS-EC2480U R2 as well as between the M4300-12X12F and FreeNAS?
b. What is the bonding mode (or Hash mode) configured on the QNAP TS-EC2480U R2 and FreeNAS?
c. Is LACP configured also between the M4300-12X12F and the PC?
d. What is the behavior of the 10GBASE-X SFP+ port LEDs on the M4300-12X12F switches?
e. What is the current firmware version of the M4300-12X12F?
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the reply
The firmware of the switch is 12.0.7.10.
The model of all fiber optic connected to M4300 :
- Lag1 between S3300 (First Floor) and M4300 : AXC761(Netgear) LACP.
- Lag2 between S3300 (Ground Floor) and M4300 : AXC7610(Netgear) LACP.
- Lag3 between S3300 (Second Floor) and M4300 : AXC7615(Netgear) LACP.
- Lag4 between M4300 ---> Qnap TS-EC2480U R2 : 02 cable : SFP-H10GB-ACU7M , CABLE-STRG Kawasaki 594060003.
- Lag5 between M4300 ---> Freenas server APY : 02 cable : PSF1PXA3MBLLN (Same Model).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I apologize for the late response. 😞
Let us update the firmware of the M4300-12X12F switch to the latest version which is v12.0.7.17 and you can download it here. Then, check if the same problem will occur.
LACP is not configured between the M4300-12X12F and the PC (L3 switch only).
Is your PC connected with 10G ethernet connection to the M4300-12X12F switch?
DaneA
