- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
M4300-24X Routing guide
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Sir,
I would like to deploy OSPF & RIP protocol using M4300-24X.
May I know if do you have an example scenario of document to refer to?
Thanks.
C.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: M4300-24X Routing guide
Hi @Carva,
I just want to follow-up on this. Does this suggestion resolve your problem?
With regard to resolve your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Eric,
Thanks for the quick response and support.
May I know if do you have some example scenario that I could refer to?
The guide that you provide is good, but I still don't know how to implement it in a real network environment.
Thanks.
C.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actually, the link above is typical network topo and confuguraiton for RIP and OSPF.
If you want to deploy RIP or OSPF in your real network and need some further more support, I suggest you provide your network topo and design requirement. According the detailed requirement, We can give you detailed suggestion.
