Orbi WiFi 7 RBE973
Reply
M4300-48X #2 PSU
jpass022
Luminary
M4300-48X #2 PSU
Greetings,
I purchased 1 M4300-52G and 2 M4300-48X, I also purchased the second PSU for all 3 units. I put the second PSU in the M4300-52G and it just worked as expected. Both M4300-48Xs show "Internal AC-2 Failed"? (The indicator on the front panel is flashing yellow)  I swapped the PSUs to see if it was a PSU issue, the problem stays with the #2 PSU slot. Is there something else I need to do on the M4300-48X that I didn't need to do on the M4300-52G?
Model: XSM4348CS|M4300-48X - Stackable Managed Switch with 48x10GBASE-T
Message 1 of 3
Accepted Solutions
jpass022
Luminary
Re: M4300-48X #2 PSU
problem solved was PDU related..
Message 2 of 3
All Replies
jpass022
Luminary
Message 2 of 3
JohnC_V
NETGEAR Moderator
@jpass022,
Thank you for sharing it here in our community! 🙂
JohnCarloV
NETGEAR Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1229 views
  • 1 kudo
  • 2 in conversation
Announcements
