Orbi WiFi 7 RBE973
Reply
NETGEAR M4100-26G no Ip Address on devices only computers
hivoltage1
Hi I have a modem/router set to DCHP and a netgear managaged switch connected to that with DCHP disabled. I can obtain an IP address from all computers but not from devices such as TV,Blue ray player. Computers get ip address 192.168.x.x but devices get ip address 169.254.x.x
Model: M4100-26G (GSM7224v2h2)|ProSAFE 26-port Gigabit Fully Managed L2 Switch
Message 1 of 7
TheEther
Guru
Re: NETGEAR M4100-26G no Ip Address on devices only computers
Are the TV and Blu-ray player wired devices?
Are they configured to use DHCP to obtain IP addresses?
Besides disabling DHCP, have you changed any other settings on the switch, like enabling VLANs?
Have you done anything special to the DHCP server on the modem/router? Set up DHCP reservations? Changed the DHCP range of addresses?
Message 2 of 7
hivoltage1
everything is wired
yes they are configured to use DHCP to obtain ip address " when i plug them direct into router it obtains correct ip"
No i don't beleve any other settings have changed
DHCP server hasn't been touched
it's odd that my computers obtain ip addresses correctly and are working fine but other devices do not.
Message 3 of 7
TheEther
Guru
Check the Ethernet cabling?
Are the link lights lit on the switch ports connected to the TV and Blu-ray player?
Do the Port Settings on the switch indicate that the ports are up?
Message 4 of 7
hivoltage1
Cabling is fine, yes ports light up.
If I enter ip, gateway, etc manually it connects correctly
Message 5 of 7
DaneA
NETGEAR Employee Retired
@hivoltage1,
Kindly try to reboot the TV and Blu-ray player while connected to the M4100-26G switch then check if it will obtain an IP address from the router.
DaneA
NETGEAR Community  Team
Message 6 of 7
DaneA
@hivoltage1,
I just want to follow-up on this.  Any updates?
DaneA
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1841 views
  • 0 kudos
  • 3 in conversation
Announcements
