- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear GS724t V4 import config to Netgear GSM4328PA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is possible aplly a configuration backup of Netgear GS724T to Netgear GSM4328PA ?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let me share the article below and use it as your guide:
How to configure routing VLANs on a NETGEAR managed switch with shared internet access
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear GS724t V4 import config to Netgear GSM4328PA
Welcome to the community! 🙂
Is possible apply a configuration backup of Netgear GS724T to Netgear GSM4328PA?
No. You might brick the GSM4328PA if you upload the configuration backup of the GS724T into it.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK DaneA, Thank you very much by the tip.
Its a pleasure to belong Community Netgear!!
Understand that i need create a new configuration on GSM4328PSA.
Any cookbook or technical sheet to configure this switch?.
Is my fisrt implementatión and is very basic, only need make a LAN whith a 7 PCs windows. Is more or less as a HUB config, that all devices see and communicate and also the management console UI of the switch on the same network.
Regards!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DaneA.
Thank you very much for your help.
I read the article and is that I need will implement.
Best regards.
