Orbi WiFi 7 RBE973
Reply
Will MASFP1GBTXST SFP from StartTech work in the GS110TP?
xeg12
Follower
I have a MASFP1GBTXST SFP unit from Startech for my Meraki MS220-8P switch and I wondere if it will also work in the GS110TP? If not what SFP module do I need to connect tot he SFP unit in the Merakiswitch?
Model: GS110TP|ProSafe 8 ports gigabit PoE smart switch
Message 1 of 2
schumaku
Guru
Re: Will MASFP1GBTXST SFP from StartTech work in the GS110TP?
Netgear does not enforce using thier own SFP modules (based on some config and fingerprints in the SFP modules) - usually most SFP modules are workable.
Modules on the ends of the fibers must be designed to work on the same fiber type and wavelength - it's not required to have the same brand/modules on both ends of the link.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 703 views
  • 0 kudos
  • 2 in conversation
Announcements
