robfantini's avatar
robfantini
stack switch configuration sync
Hello
 we have a stack  of 3 switches.
**Question**:  When configuration a configuration change is done,   do the settings automatically go to the Standby switches?
I ask because   one time  we changes a setting - dhcp helper address -  and when another switch took over as master,  that setting was not on the switch.   Now that could have been due to operator error - like not saving the configuration.
  • Hi Rob
    I believe you have a stack of Fully Managed switches, M4300 series.
    Yes, configuration is shared across the stack. When there is a configuration change, the settings in running configuration are synchronized across all switches in the stack (stack master = management unit; backup master = standby management unit; stack members = slaves). The same, but independently, the startup configuration file is also shared across all switches in the stack.
    But, in a Fully Managed switch, any configuration change must saved in order to see the "running configuration" (show run) saved as "startup configuration" file that will survive the reboot.
    I am afraid the configuration wasn't saved in your instance below. I hope this helps.
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi Rob
    • robfantini's avatar
      robfantini
      thank you for the answer.   I must have not done the save.
ProSupport for Business
