- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Anyone seeing internet connection drops with Armor enabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I installed Armor on my 2 1/2 year old Orbi and started having internet drops once I streamed content on my TV. I had the same issue when I thought I had removed Armor but apparnetly I had not. I figured I'd need a new router soon anyway, so I bought a replacement RBR50 and it set up fine. Then it dropped internet again. I did a factory reset and have not yet added Armor back in (I had purchased a year subscription). I have also had no internet drops. I want to add Armor back in but am a bit gunshy given the experience of the past week. I will likely do so soon, but am interested if I am the only one experiencing the internet drops with streaming or otherwise. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Anyone seeing internet connection drops with Armor enabled?
Anyway, I rebooted the mesh system manually, router and each satellite,then internet started working again after everything synced back up.
Happiness lasted less than 10 minutes.
My solution 2 days ago, disabled Netgear Armor, and have had no more disconnects since.
So, yes, it's a Netgear Armor issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks so much for the reply. I am fast coming to the conclusion that it has t be an Armor issue. I have pretty much narrowed it down to that. I unfortunately bought a year's subscription and will now have to ask them for a refund. Even if they won't I will not enable it again. I almost feel like I have ransomware on my machine as I have lost internet 10 times at least within a week. If anyone else reads this please post your experience. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do have 2 extra layers of security in my network, which has me at peace for now;
I have a Fing Box (great to secure your internal network and keep away spoofing devices from your wifi), and a Cujo Smart firewall, set up between my modem and my RBK system.
Those 2 devices block enough potentially malicious traffic to keep me feeling safe.
Plus, I also have Bitdefender Total Security in all the devices for my family (laptops, phones, tablets, etc.)
All in all, I'm ok keeping the Orbi just as my mesh system, and relying on something else for security.
But, yes, Armor is broken and a bit. Hopefully they will fix it by the time I'm up for my bitdefender renewal (9 more months, hehe).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I too have random connection drops, reset or the router restores it or deactivating Armour.
@netgear: is there a beta firmware available which corrects this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've had the exact same experience with internet dropping out periodically after I enabled Armour. When I updated my router and saw this new option I was excited to give it a try. So glad I didn't pay for anything yet. After I disabled Armour things went back to normal. So unfortunate that Netgear released such a troublesome program that is supposed to help not hinder.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't heard from Netgear about this issue.
Bumping the post to see if they say anything.
Has there been an update to fix it?
I just updated my Orbi to V2.3.5.30, but don't want to risk enabling Armor and break everything again. (Although, the trial period ended for me already, so maybe it doesn't matter anymore).
My Bitdefender total security subscription is up in about 6 months, and I would like to know if it's worth it to get Armor instead, since it includes Total Security.
Does anyone know anything new about this?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been running Armor for over three months now; and the only time I experienced internet drops was when I had the daisy chain option enabled. If you only have one satellite, daisy chain will slow down your network and cause regular internet drops -- at least, this has been my experience. Once I disabled daisy chain, everything went back to normal, with no hiccups whatsoever. I have since added a second satellite, as the signal was weak in one area of our house. I re-enabled daisy chain, and now the signal is very strong in all corners of the property, with zero internet drops.
So based on my experience, if I were you, I would definitely go with Armor once the BD Total Security licence runs out since Armor includes BD Total Security on specific devices for protection when working away from the home network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seeing the same thing here. Every time it runs a vulnerability scan,
it kills my wifi. The only way to reconnect is to reboot the router, which is a nuisance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having same issue it seems. Internet just randomly stops. Can't access router dashboard. Unplug/plug back in, then it's back for a while. Tested all the cables, they're good. Called the ISP, no downtime of modem. Unfortunately just paid for Armor subscription.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
Thanks for confirming I'm not going crazy.
I've only had Armor activated on my RBR50 for less than two days and I've already had 4 internet dropouts that required rebooting my router and satellite. That is more reboots than I've needed over the past 9 months in total since buying the device.
I'm surprised there isn't a firmware update for what is obviously a problem to do with this new offering they are trying to sell. I guess my free trial is going to go to waste now, because I'm not going to put up with this level of unreliablility. This new Armor offering is a nice idea but in practice it is worse than useless and I'm disabling it now.
UPDATE: I do also have the Circle option enabled. After reading another post, I'm wondering whether others in this thread also have Circle active. It is possible this internet connection drops are more frequent when multiple optional services are active on the same Orbi.
Thanks, Matt
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @DawMatt . As I wrote in my earlier post, the only time I experienced internet drops was when I had the daisy chain option enabled with only one Orbi satellite. If you only have one satellite, daisy chain will slow down your network and cause regular internet drops -- at least, this has been my experience. My Armor 90-day trial subscription ran out and have not yet decided to purchase a one-year subscription. However, during the trial period, I added a second Orbi satellite and re-enabled daisy chain; and everything was working fine, with no interruption whatsoever. Circle is not active, never was.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks @Orbi-Roc .
I've now disabled the daisy chain option. Once I've proven that the network is stable again I might give it another go. Though it seems strange we need to disable a default setting for a new product feature to work.
Thanks, Matt
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi again @DawMatt . Well, I can't find the article anymore, but I do recall something about daisy chain being effective only one more than one satellite is on the network ... And that makes perfect sense, as daisy chaining would have nothing to link if you only have only one satellite.
So yes, I agree with you, Netgear shouldn't have this option enabled by default. Moreover, it should be annotated appropriately, to inform users that daisy chaining should be enabled only when two or more satellites are on the network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Orbi-Roc ,
Turning off that setting didn't end up helping me. I now have Armor disabled (using the settings in the mobile app) and the daisy chain option disabled, and I'm still having to reboot my Orbi devices at least 3 times a day to get internet connectivity running. Very frustrating as Orbi had been rock-solid until I decided to try out the Armor offering.
The other day my son showed me that his laptop had its internet disabled because it was "past his bed time". According to Circle anyway. It was 11 AM on the weekend and definitely within his configured internet hours so something was not right. Rebooting the Orbi fixed the issue. It makes me wonder whether the issues I'm experiencing are worse because I was trying to use Circle and Armor at the same time.
I'm not sure what else I can do to try to resolve the problem. If something doesn't improve soon I'll probably take them back to the store and try to exchange them for new devices. This seems like massive overkill but given we are only offered 3 months of support that doesn't leave me a lot of other options.
Thanks, Matt
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I rolled back to the previous version of the firmware, the one without Armor,
and the router has been rock steady since. No issues at all.
EL
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DawMatt -- I assume that you have already checked firmware updates and that you're running the latest version (V2.5.0.38). If you're absoletely sure that nothing else is getting in the way, then perhaps your Orbi is defective.
One more thought: even prior to Armor, I was experiencing chronic internet drops when 4K Netflix streaming. The satellite RBS50 was sitting just two feet away from the TV. Internet drops vanished COMPLETELY after I plugged the TV directly into the Orbi sat. Not a single reboot in over a year.
Other than that, perhaps you can try a factory reset, which I understand (judging from other posts) can clear up many issues. In fact, Netgear recommends a factory reset following every firmware update. The only downside is that you'll have to reconfigure everything; I think that using a backup of your settings will just carry over the problem, so that's not an option. Since you'd have to reconfigure any way if you were to buy new devices, you may want to give this a shot and see what happens. Good luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having the same issue after installing Armor. Router will lose connection every few days. I have to power cycle the router for it to work. Phone support has been terrible. Firmware is up to date.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Orbis and had the same experience. Tried everything that was recommended but it kepy dropping the ocnneciotn requiring a total reset each time. Finally dumped Armor and have not had a single dropout since (over a year if I recall correctly).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thats great. I just reverted to older firware then installed latest one again without enabling Armor. Will see if this works. If I don't loose connection after a few days i'll know the answer 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem went away for a couple months. It's back to random failure
@splatooft wrote:Having same issue it seems. Internet just randomly stops. Can't access router dashboard. Unplug/plug back in, then it's back for a while. Tested all the cables, they're good. Called the ISP, no downtime of modem. Unfortunately just paid for Armor subscription.
Firmware up to date. Lights on router all normal showing there's internet, but nope there's nothing. No lan, no wifi, no internet, therefore, no administrative dashboard. Have to unplug the router for 30 seconds. At least now it's not completely factory resetting the router as had been happening.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Too bad they were never able to fix some of the issues that make this otherwise powerful system a very expensive set of bricks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@splatooft wrote:The problem went away for a couple months. It's back to random failure
And I can't seem to find any older firmware to download. That was suggested by Netgear, but when I goto Netgear Community Downloads and put in the router model, it only shows the latest firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's not even Armor anymore, everything is broken.
I just bought an Amplifi HD system, and an extra Amplifi HD router to mesh hardwired.
I'll just put the Orbi up for sale, at 1 router and 3 satellites, I should be able to get about 300 dollars and somewhat cover some of the cost for the Amplifi.
I wish you all good luck dealing with Netgear, I'm done getting the runaround from them with serious issues like this.
