Orbi WiFi 7 RBE973
Reply
Armor & Bitdefender - are they installed?
JimmyW
Luminary
I'm setting up a new RAX5400, which supposedly comes with a trial of Armor, However, I don't want to use Armor, but I don't see that it's installed. I didn't find a setting for it, and all I see in the Nighthawk app is the option to install Bitdefender, as in the screenshot. So, am I correct in assuming that Armor/Bitdefender is not installed? Is there a difference between Armor and Bitdefender? Thanks.
Message 1 of 3
microchip8
Master
Re: Armor & Bitdefender - are they installed?
You have to enable and agree to use Armor. By default, it's off.
Message 2 of 3
JimmyW
Luminary
Thanks, but I learned that mine was enabled. I called Netgear and learned that Armor must be accessed through the Nighthawk. By doing so and going to security settings, I saw that I had to toggle Armor from on to off/
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 425 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
