Orbi WiFi 7 RBE973
Reply
Armor does NOT show URLs!
RykGroff
Nighthawk Blocking Malicious Sites but What Are They?
Recently got a Netgear router and downloaded Nighthawk as instructed. It tells me often that it's blocked a malicious site, but I don't see any place I can go for it to actually TELL me what those sites are. Is there no way to find this out?
Samsung A54 running Android 14
Message 1 of 8
Guru
Re: Nighthawk Blocking Malicious Sites but What Are They?
Message 2 of 8
RykGroff
When I click on the Security tile I see no "Threats Blocked", but there is a "Network Security" and when I tap on "See more" it says "6 threats detected & blocked" but I don't see a list of URLs.
Message 3 of 8
Guru
I don't have armor anymore but there's a way within the app to see whats blocked. You might have to click on the threats seen
Message 4 of 8
RykGroff
Still not seeing any URLs.
Here's what I'm doing:
1. Launch Nighthawk
2. Tap "Security & Support"
3. Tap "Threats detected and blocked" under "Your network is protected"
4. On the "Threats" page there's a list of "Malicious_host"s found
5. If I click on one of the "Malicious_host"s I get a "Threat Blocked" page
6. I see no URLs. If I click on "Learn More" all it says is "Malicious_host" and "OK"
I would REALLY like to know what this app is blocking!
Message 5 of 8
Guru
Is it causing issues?
Message 6 of 8
RykGroff
No, but I still would like to know what websites I've been visiting that Netgear Armor has a problem with.
Message 7 of 8
RykGroff
When I search Support here and ask how to see the URLs Armor is blocking, it says:
To Unblock Websites in NETGEAR Armor:
  1. Launch the Nighthawk or Orbi app from a mobile device that is connected to your router’s network
  2. Tap Security - The NETGEAR Armor dashboard displays
  3. Tap Threats Blocked - A list of suspicious URLs NETGEAR blocked displays
  4. Tap on the URL that you want to whitelist
  5. Tap Add to Unblocked - A warning displays
  6. Tap OK
This is not true. All I ever get after clicking "Learn More" is "Malicious_host" and "OK".
This is NOT helpful AT ALL!
(Nighthawk ver. 2.42.1.4373 on Android 14)
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 623 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
