Orbi WiFi 7 RBE973
Reply
Armor removal
BeachSnoopy
Armor removal
So I don’t see many replies to anything, but how does one remove the Armor service? Just need to call? We have had issues since install and don’t have 6 hours to spend on the phone w a service guy to fix, just remove it.
Message 1 of 3
Guru
Re: Armor removal
With in the Orbi or Nighthawk app, you can disable it.
To stop the subscription, you'll need to contact NG support or try here:
https://community.netgear.com/t5/NETGEAR-Armor/Armor-Help-and-Information/td-p/2211063/jump-to/first...
To remove it from a router, you'll need to factory reset the router and setup from scratch and use a wired PC and web browser to set it up. Avoid using the mobile apps to set up the router as they may re-enable Armor during the setup routine there.
Message 2 of 3
BeachSnoopy
Re: Armor removal
And why is this so invasive and not allow you to control? I’m not crazy Facebook, but since I did this I can hardly even check Facebook or my car pages…like this Netgear deal is blocking me???
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 498 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
