Orbi WiFi 7 RBE973
Reply
I have two stes of Orbis in two apartmemts. Do I need two subscriptions to Armor bitdefender securit
hectorluis
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Accepted Solutions
Guru
Re: I have two stes of Orbis in two apartmemts. Do I need two subscriptions to Armor bitdefender sec
If you have one set as primary and the 2nd set running in access point mode and connected, then you'd only need one.
If you have them running on different modem's (own independent setups), then you'd need 2.
Message 2 of 3
All Replies
Guru
Message 2 of 3
hectorluis
Thank you my case is the second, this solves my question.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2522 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
