- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 IPv6 stops working after installing netgear Armour.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi I have recently activated Netgear Armour on my RAX 120 router in the UK. Everything was previously running pretty fine for a couple of years. However with Armour activated IPv6 does not work, when I disable armour IPv6 works again.
Another symptom is that my wired Orbi satellite (Orbi router is in AP Mode) fails to pick up the internet connection when Armour is enabled.
With Armor disabled on the RAX 120 everything works as normal again.
1) Is armour not compatible with my set up?
2) Is there a dashboard I can access to see what Armour is blocking (Can't see it on routers login page or Nighthawk app
3) If armour is not compatible can I get my money back?
Many thanks in advance for any advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 IPv6 stops working after installing netgear Armour.
I recommend you reach out to NG support:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
