Orbi WiFi 7 RBE973
Reply
Unable to deactivate Armor
Mark382
Initiate
After turning off “Enable Netgear armor” It gives an error of “process is taking too long, try again!”
How else can I disable it? Keeps printing “curl/7.59......” on first page of every document I try to print!!!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
DexterJB
NETGEAR Moderator
Re: Unable to deactivate Armor
Hi @Mark382, please try using another mobile device to disable Armor via the Orbi app. What is the firmware version of the Orbi and what is the app version that you have installed?
Dexter
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1943 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
