Orbi WiFi 7 RBE973
Reply
How to actual get support?
DDT3
Hello,
I have a premium insight subscription to manage 3 GC110(p) routers. I  have some issues with the Insight portal: it appears it has a live of it's own and configurations keep changing while I have no clue why.
So I would like some support for the Insight portal but it appears I can only get that if I report an issue on one of the registered switches, which I can't because these are no longer covered...
How can I get support?
(The issue itself: https://community.netgear.com/t5/Insight-Managed-Smart-Cloud/VLAN-settings-keep-changing-all-the-tim...)
Message 1 of 2
JulienR
Sr. NETGEAR Moderator
Re: How to actual get support?
Hi @DDT3,
I will get a member of our support team to get in touch with you.
Thank you.
Best Regards,
Julien R.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 829 views
  • 1 kudo
  • 2 in conversation
Announcements
