Orbi WiFi 7 RBE973
Reply
How to configure WAC510 to prefer 5.0 Ghz band over 2.4 ghz band
Pugfom
my devices are connecting to the 2.4 Ghz band when the faster 5.0 band is available.  Is there a way to configure the WAPs to prefer the faster 5.0 ghz band?
Message 1 of 7
Accepted Solutions
SalauddinK
NETGEAR Expert
Re: How to configure WAC510 to prefer 5.0 Ghz band over 2.4 ghz band
Hi Pugfom,
You can enable the Bandsteering feature on your WAC510, which steers the Wireless devices (Dual band Capable) to the 5 Ghz band.
To configure this from Web UI,
Login > Management > Confgiuration > Wireless (Basic) > WLAN Settings > Under preferred SSID#
Do check for the attachment for reference, hope this helps.
Please note :
Band Steering largely depends on the Wireless environment aroud like (Interference, Congestion etc)
Thanks,
Salauddin
Message 2 of 7
All Replies
SalauddinK
NETGEAR Expert
Hi Pugfom,
Please note :
Thanks,
Salauddin
Message 2 of 7
RaghuHR
NETGEAR Expert
Hi @Pugfom
Are you able to check the band steering feature as explained by @SalauddinK
Let us know if you have any questions. If you are satisfied then you can mark this thread as 'Accept as solution'
Thanks
Raghu
Message 3 of 7
schumaku
Guru
As this is under the NETGEAR Insight Management App subforum, I fail to see this as a solution. How/where can we enable Bandsteering for the WAC505/WAC510 in IM3?
Message 4 of 7
fordem
Mentor
The insight app is now at ver 4 - I still don't see a way to enable band steering from the app.
Model: Insight Basic
Message 5 of 7
schumaku
Guru
Go to [Networks] -> WiFi  ....select the SSID .. and check the WiFi Settings
Message 6 of 7
nmhTester
NETGEAR Expert
To complete the answer.
If Premium subscription:
Log in to Insight Cloud portal
https://insight.netgear.com
Network-Location->Wireless->settings->SSID configuration
Enable Band steering for the SSID. It will automatically get enabled for all APs in that location.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 7430 views
  • 1 kudo
  • 6 in conversation
Announcements
