Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connecting ReadyNAS Ultra to remote NUT server
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-30
05:44 AM
2013-04-30
05:44 AM
I am trying to get my 2-disk ReadyNAS Ultra (x86) to understand it should connect to a remote UPS NUT server.
The ReadyNAS can do this already, as long as there is another ReadyNAS it should connect to. But when the Network UPS Tools (http://www.networkupstools.org) server runs on just a plan Linux box, I cannot get the ReadyNAS to connect and get UPS status.
When logged into a shell on the NAS, I can use command line tools to connect to the NUT server, so that server is indeed working, no IP numbers blocked etc.
Question is: how to get the NAS' user interface to pick up the same information..
Any suggestions/solutions?
Message 1 of 9
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-30
06:19 AM
2013-04-30
06:19 AM
Re: Connecting ReadyNAS Ultra to remote NUT server
Did you try to connect to the NAS using user=monuser, password=pass ?
Message 2 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-30
06:53 AM
2013-04-30
06:53 AM
Well the UPS is connected to a small headless server, where the NUT server is also running.
I'd then like to get the ReadyNAS built-in software to connect as a client to that NUT server, but the only thing I can configure is the IP address by the check box named "Enable monitoring of UPS physically attached to a remote ReadyNAS" (on the Power tab of the System pane)
The reason for this setup is simply that the ReadyNAS NUT version is way old and doesn't recognise the UPS, whereas the latest version of NUT does recognise the UPS.
So, running NUT on the headless server works well, and the ReadyNAS (and some other devices) will then connect as clients to the NUT server.
So it's not connecting to the NAS that is the problem, but rather connecting FROM the NAS..
Message 3 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-30
06:56 AM
2013-04-30
06:56 AM
Well did you try setting that username and password as the credentials on the remote NUT server. The ReadyNAS probably automatically attempts to use those credentials to connect to the NUT server
Message 4 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-30
07:04 AM
2013-04-30
07:04 AM
Yup, that was the first thing I tried. No luck.
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-30
07:27 AM
2013-04-30
07:27 AM
Maybe try moving the connection to the ultra, and making the headless server the client???
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-30
07:30 AM
2013-04-30
07:30 AM
For example, when executing on the NAS:
where 192.168.1.12 is the IP of the headless server where NUT server is running, I get the expected result:
So... the communication from NAS to NUT server is working.
The /usr/local/ups/etc/upsd.users file on the headless server contains:
I have restarted all the NUT related processes on the headless server, no change..
/bin/upsc powerwalker@192.168.1.12
battery.charge: 100
battery.voltage: 27.10
battery.voltage.high: 26.00
battery.voltage.low: 20.80
battery.voltage.nominal: 24.0
device.type: ups
driver.name: blazer_usb
driver.parameter.pollinterval: 2
driver.parameter.port: auto
[monuser]
password=pass
upsmon slave
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-30
07:31 AM
2013-04-30
07:31 AM
StephenB wrote: Maybe try moving the connection to the ultra, and making the headless server the client???
Problem is that the NUT version that is loaded on the Ultra does not recognise the UPS I have*.
I tried a gentle upgrading of NUT on the Ultra, but it just broke the Ultra's UI-to-NUT integration.
* PowerWalker VI 1000 LCD, with USB connection.
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-30
08:38 AM
2013-04-30
08:38 AM
Ok, some progress.
Kind of obvious... as usually is the case when you've looked at something for too long.
The UPS has to be named "UPS" and nothing else on the headless server.
Then the NAS picks it up, but still reports an error as NUT doesn't report back the variables that the NAS software expects (the UPS icon in the NAS UI blinks yellow, and says "UPS 1: Remote Error, Battery Charge: 100%".
Not quite there yet, but progress.
Message 9 of 9
