Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Happy
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-06-27
12:02 PM
2011-06-27
12:02 PM
Happy
It was a dog to get going
there was some glue type garbage between the SODIMM and the socket which gave me "corrupt root"
it required a firmware update and many resets and finally.....
It worked !
Tips for the technically advanced:
Install:
togglessh
enablerootssh
apt_1.0
download from:
http://www.readynas.com/download/addons/4.00
From the silly GUI in advance mode
System>Update>local>
upload verify and install the files
once you have rebooted the requisite number of times you can
apt-get install <whatever you need!>
inc Gcc etc and even compile stuff from source on the NAS
WELL DONE NETGEAR
Happy happy happy
It worked !
Install:
togglessh
enablerootssh
apt_1.0
download from:
WELL DONE NETGEAR
Happy happy happy
Message 1 of 10
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-02
04:23 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-02
05:41 AM
2011-10-02
05:41 AM
Re: Happy
There is no need to install the toggle ssh add-on (provides SSH access for support use only) or the EnableRootSSH add-on (provides SSH access for use by us end users). Only if you want to do stuff via the command line e.g. use "apt-get" do you need to enable SSH access.
Message 3 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-02
04:05 PM
2011-10-02
04:05 PM
Re: Happy
Thanks mdgm. I was coming back here to post a reply (as I had learned a lot more since I made the above comment).
As you say, there are various other maintenance reasons that could cause a person familiar with the Linux OS to want to use ssh. After having installed EnableRootSSH, the ability to "toggle" - turn ssh on/off via the re-installation of ToggleSSH, is very useful from a security perspective.
Message 4 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-02
04:10 PM
2011-10-02
04:10 PM
Re: Happy
The EnableRootSSH add-on is not a Toggle add-on. ToggleSSH add-on is to enable/disable SSH access for support use. I don't recommend using this add-on with EnableRootSSH. The proper thing to do is to set a password for SSH that is difficult (if not impossible to crack) and not port forward port 22 to your NAS so SSH isn't exposed to the web.
Message 5 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-02
04:49 PM
2011-10-02
04:49 PM
Re: Happy
I see... Thanks.
Due to my circumstances I will be using ssh less than once in a blue moon, (possibly never again on the Duo) so I'll carry on with my improper solution.
Message 6 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-02
04:56 PM
2011-10-02
04:56 PM
Re: Happy
Part of the point of having SSH access always enabled is so that you can use it when you need it once in a blue moon (e.g. if Frontview won't work and you need to e.g. remove an add-on via SSH).
Message 7 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-02
05:06 PM
2011-10-02
05:06 PM
Re: Happy
This begs the question: What is "wrong" with using ToggleSSH to turn ssh on/off in these circumstances?
It seems to me that it offers more security using it this way under blue moon circumstances. I'd rather have my ssh turned off completely when I'm not using it than rely on hard passwords & uncommon ports.
Message 8 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-02
05:18 PM
2011-10-02
05:18 PM
Re: Happy
ToggleSSH deactivates SSH for both tech support and the user or turns it on for tech support. It has been known to be problematic at times re-enabling SSH access using EnableRootSSH after using ToggleSSH.
Also if you lose access to Frontview you can't re-enable SSH access. What good is having SSH disabled when you need to use it to fix a problem so you can use Frontview again. You don't need to use an uncommon port for SSH. If you don't expose port 22 on the NAS to the internet (it won't be unless you configure it to be in your router) then someone would need to be on your local network to even be able to attempt to hack into your NAS using SSH.
Message 9 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-02
05:40 PM
2011-10-02
05:40 PM
Re: Happy
Thanks mdgm, now I know. 🙂
My Duo is not exposed to the net, so on your advice I will enable ssh, & hope that I never have to use it to recover from a lost Frontview.
Your advice is much appreciated, I will modify a previous post accordingly.
Message 10 of 10
