- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Hard Drive Failure RN104
- Mark as New
- Bookmark
- Subscribe
- Permalink
Readynas RN104 4x3TB disks (Seagates I think) RAID 5 running OS 6.10.3 and at least 1 disk has failed. Received message (can't remember exactly what now) in Raidar but heard clicking inside unit (so definitely a drive failure). Rebooted but then when I go into Raidar now, then Admin page, it brings up screen to start setting up new RAID.
The data is backed-up so not too concerned about data loss but I've like to get to the logs and understand what happened and which drives have failed.
NooB on linux but can follow instructions re SSH and required commands.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Hard Drive Failure RN104
One option is to power down the NAS and test the disks with SeaTools. Label the disks by slot as you remove them.
RAIDar 6.5 should give you an option to download the NAS logs and run diagnostics. Have you tried that? The current version of RAIDar is here: https://kb.netgear.com/20684/ReadyNAS-Downloads
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks will give that a try.
Got Raidar 6.5.0 now so will see if can get logs that way as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok when I try to get logs via Raidar I get attached image - 'Healthy' status doesn't make sense. Display NAS says 'READYNAS is in safe mode'. Can hear clicking / beeping from unit.
Need to locate caddy to do Seatools drive checks. Will revert on outcome.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is quite odd. The screen saying the NAS is in safe mode and the RAIDar status don't seem to jive at all. With that RAIDar status, you won't be able to download logs (if there even are any accessable).
The first thing is to identify the bad drive and try booting with just the others. Hopefully, the NAS will then be able to sort things out. I'm suspecting that one bad drive is creating problems across the entire SATA system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree that is the right next step.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for guidance. Had to buy a disk caddy as lost mine somehow during lockdown!! Will revert with update in a couple days once sorted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well this is weird to say the least.
Have run both Seatools and WD diagnostic tools on the drives (1 x WD30EFRX, 1 x Seagate ST3000DM001, 2 x Toshiba MG0ACA400E) with the WD diagnostics showing no errors for SMART / Quick Test. Seatools showed no errors for all Short Generic Tests but did flag SMART errors for all drives but I couldn't work them out.
So reinserted drives and all appears in order with RAIDar showing drives all healthy and data intact.
Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The short test amounts to a confidence test. You really need to run the long ones.
Perhaps download the log zip file, and post disk_info.log. Best to do a copy/paste ( using the </> tool in the forum)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Device: sdd Controller: 0 Channel: 0 Model: TOSHIBA MG04ACA400E Serial: 57U4Y066FJKA Firmware: FP3B Class: SATA RPM: 7200 Sectors: 7814037168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 2fe585ba Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 29 Start/Stop Count: 11050 Power-On Hours: 22803 Power Cycle Count: 43 Load Cycle Count: 11050 Device: sdc Controller: 0 Channel: 1 Model: WDC WD30EFRX-68EUZN0 Serial: WD-WMC4N0H43XXN Firmware: 82.00A82W Class: SATA RPM: 5400 Sectors: 5860533168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 2fe585ba Health data ATA Error Count: 6216 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 32 Start/Stop Count: 16922 Power-On Hours: 34840 Power Cycle Count: 91 Load Cycle Count: 16918 Device: sdb Controller: 0 Channel: 2 Model: ST3000DM001-1ER166 Serial: W500XWSR Firmware: CC25 Class: SATA RPM: 7200 Sectors: 5860533168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 2fe585ba Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 End-to-End Errors: 0 Command Timeouts: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 32 Start/Stop Count: 20095 Power-On Hours: 40866 Power Cycle Count: 70 Load Cycle Count: 20109 Device: sda Controller: 0 Channel: 3 Model: TOSHIBA MG04ACA400E Serial: 6741Y0S4FJKA Firmware: FP3B Class: SATA RPM: 7200 Sectors: 7814037168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 2fe585ba Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 31 Start/Stop Count: 18618 Power-On Hours: 22781 Power Cycle Count: 30 Load Cycle Count: 18619
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Agreed. Have removed drive and running extended long tests but will look to replace anyway.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd avoid the WD30EFAX. EFAX drives between 2 and 6 TB all use SMR (larger ones do not). This created quite a stir when it came out a few months ago. WD announced they create a new "Red Plus" line in response - but they haven't yet.
Don't go with another Barracuda either - many of those models are also now SMR.
Instead, I suggest going with the older WD30EFRX (still available for reasonable prices) or get an Ironwolf.
