- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Home folders share not working for SMB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all,
I have a ReadyNAS 102 with 2x 2tb raid setup as mirror. Firmware History 6.25 --> 6.40 ---> 6.50. I noticed there was a Share Called Home Folders. I have enabled SMB, FTP under the Access tab. When I login into the FTP site as a user I can browse the folder called "home". I have tried everything I can think of to try to find the SMB share called home like the FTP site. Any suggestions would be great. I have been reading other forums suggesting to turn off anonymous on the home folder share but I can't find this in firmeware 6.50.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Inside home there is a subfolder for each user account. When you using SMB, you log in as user X you will see the folder X - but not home itself. If you aren't seeing any user folder, then you are using guest (anonymous) credentials. The solution is to go into windows credentials manager and enter the user account you want to use with the NAS. You still won't see "home", just the private home share for that user.
FTP works differently. If you have FTP access for home shares, then you can see the home folder, but if you log in as user X and descend into it you will only see subfolder X, and not the others.
Note that if you log in as admin, things work slightly differently with SMB. Admin can access the full data volume using SMB - in which case you see everything including home.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Home folders share not working for SMB
Thank you. Windows Credentials Manager work great though I had to add a "Windows Credential" not a "Generic Credential." I added both the IP address and the DNS name for the ReadyNAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Exactly right.
