× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Moving disk to empty place, with same order
Jttgg
Tutor
Hi,
I have a 628x running 6.10.1, with 6 disks on place 1,2,3,4,5,6. 7 and 8 are empty.
I'd like to move disks, keeping the exact same order, to 1,2, 4,5, 7,8, with 3 and 6 empty, in order to improve cooling.
Is it possible without breaking the raid ?
thx
Model: RN628X|ReadyNAS 628X - Ultimate Performance Business Data Storage - 8-Bay
Message 1 of 3
Accepted Solutions
Marc_V
NETGEAR Employee Retired
Re: Moving disk to empty place, with same order
@Jttgg
We do not suggest doing such procedure since it might put your data at risk unless you have a full backup of data in case of any failure and a very good reason why you would do this.
To answer your question, This should be possible without getting the RAID inactive but you should consider checking the disks health first. The RAID information is actually on the Disks so transferring them to another NAS or another Bay should get it detected and properly mounted.
You can do this while the NAS is turned OFF and NOT while it is turned ON. The disks will be recognized as failed if you try to do hot swap.
HTH
Regards
Message 2 of 3
All Replies
Marc_V
@Jttgg
HTH
Regards
Message 2 of 3
Jttgg
Tutor
Understood, thank you.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 982 views
  • 1 kudo
  • 2 in conversation
Announcements
