× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
READY NAS 102
Nube09
READY NAS 102
HELLO, CAN SOMEONE HELP ME. MY SON HAS GONE TO STUDY AWAY. AND IT HAS A PROBLEM ACCESSING THE NAS, THE RESIDENCE HAS WIFI.
AND YOU CANNOT ACCESS THE NAS AT ANY TIME, BECAUSE IT CAN BE. HOW CAN YOU SOLVE IT? IT WAS ONCE, BUT NOW IT'S NO LONGER.
CAN SOMEONE HELP US.
Message 1 of 24
Guru
Re: READY NAS 102
Do you know how to access the NAS admin web UI?
Message 2 of 24
Nube09
Re: READY NAS 102
Yes, but it is slow and bad at the file viewing level, since it is via Wi-Fi.
You need the program to work.
To manage the nas from the windows file manager.
Message 3 of 24
Guru
Re: READY NAS 102
@Nube09 wrote:
Yes
Are you seeing any errors on the log page?
Have you tried rebooting the NAS from the web ui?
Also, what errors are you getting when you try to use file explorer?
Message 4 of 24
Nube09
Re: READY NAS 102
No, it stays connecting with no results.
If it does not work.
I don't use the file explorer, because it doesn't start the nas from the Readyloud app.
Thank you
Message 5 of 24
Guru
Re: READY NAS 102
Are you saying you use ReadyCloud????
Can you try file explorer?  Enter \\hostname in the address bar (substituting the real NAS name for the hostname placeholder).  Be careful to use the correct slash - //hostname will launch your browser, which we don't want.
Message 6 of 24
Nube09
Re: READY NAS 102
It is already another way, but in the same network.
it's not the same lan, that's the problem.
Thanks a lot.
Message 7 of 24
Guru
Re: READY NAS 102
Can you ping its IP address?
Message 8 of 24
Nube09
Re: READY NAS 102
I do not can.
Message 9 of 24
Guru
Re: READY NAS 102
@Nube09 wrote:
I do not can.
Sorry, I am having trouble if you are saying
  • "yes I can ping the IP address"
  • "no I can not ping the IP address"
or maybe
  • "I don't know how to do that".
It would be helpful to have a description (perhaps a diagram) on how your network is set up, including any subnets you have on different LAN segments.
Message 10 of 24
Nube09
Re: READY NAS 102
"no I can not ping the IP address".
Message 11 of 24
Guru
Re: READY NAS 102
Thanks.  Then you must not be able to open the NAS web ui either.
That you tried restarting the NAS?
To gracefully shut down your system using the Power button:
1. Press the Power button.
The Power LED blinks, prompting you to confirm the shutdown.
2. Press the Power button again.
The system shuts down gracefully
Then power it back on again.
Message 12 of 24
Nube09
Re: READY NAS 102
The web interface does work and I did try rebooting the NAS.
The computer is not on the LAN
Message 13 of 24
Guru
Re: READY NAS 102
Are you using ReadyCloud to reach the web interface? Or just browsing to the web interface?
Are you meaning to say that it is connected to your home wifi (but not ethernet)?
Message 14 of 24
Nube09
Re: READY NAS 102
YES, I AM USING READYCLOUD TO ACCESS THE WEB INTERFACE, BUT I WOULD LIKE TO ACCESS MY NAS DIRECTLY FROM READYCLOUD.
I am connected to the Wi-Fi of a different house than where the device is installed.
Message 15 of 24
Guru
Re: READY NAS 102
Ok.  I don't use ReadyCloud myself, so I can't help much on this.
  1. Is this a new problem, or have you always had this performance issue?
  2. Have you tried rebooting the NAS using the web interface?
Message 16 of 24
Nube09
Re: READY NAS 102
If it's a new problem
and
Yes I have tried rebooting the NAS from the web.
Message 17 of 24
Guru
Re: READY NAS 102
and
Ok/  Have you tried speedtest.net to check that your home's internet speed (upload and download) hasn't changed?
Message 18 of 24
Nube09
Re: READY NAS 102
No. but it has changed because it goes through wifi and before it was fiber.
I am in a student residence and it goes through wifi.
I don't know how to solve the problem
Message 19 of 24
Guru
Re: READY NAS 102
It might be an internet speed issue on your end (and not the NAS or ReadyCloud).
Try going to speedtest.net in your browser, and let us know the upload and download speed it measures.
Message 20 of 24
Nube09
Re: READY NAS 102
60 up and down
Message 21 of 24
Guru
Re: READY NAS 102
@Nube09 wrote:
60 up and down
Ok.  That is faster than 5 GB/hour.
Are you seeing sluggish speeds when downloading a large file from a website (not the NAS)?
Also, when you say 5 hours for 25 GBs, is this for a single 25 GB file?  Or is it for a folder that holds a lot of small files?
Message 22 of 24
Nube09
Re: READY NAS 102
I don't understand what you mean.
The Problem is that you cannot access the NAS from the readycloud application.
Message 23 of 24
Guru
Re: READY NAS 102
Sorry, there is another thread focused on a performance/speed problem, and I got that tangled up with this one.
But you can reach the NAS using readycloud.netgear.com?
Message 24 of 24
Top Contributors
Discussion stats
  • 23 replies
  • 2477 views
  • 0 kudos
  • 2 in conversation
Announcements
