Orbi WiFi 7 RBE973
Reply
ReadyNAS 316 reacts slowly, slower than an old ReadyNAS NVX
DietmarL
Hi,
I have two ReadyNAS
1.) ReadyNAS NVX
2.) ReadyNAS 316
Although the 316 is much younger and not the full of data yet, it is still much slower in showing the content of a directory or copying data than the old NAS NVX. When copying bigger files from my iMac to the 316, nearly no other activity is possible. The NAS seems too busy. Both NAS are in the same network and are connected via the same switch (GS116E).
The 316 has been setup with new harddrives just in mid 2017.
Anyone an idea what to check?
Thanks
Model: rn31600|readynas 300 series 6- bay
Message 1 of 5
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNAS 316 reacts slowly, slower than an old ReadyNAS NVX
Welcome to the community!
Which firmware is on each unit?
Which services are you running?
Which add-ons/apps are you running?
Which protocol are you using to access the NAS from your Macs?
On current ReadyNAS OS 6 firmware under System > Settings > Services, if you click on the SMB button there is an option to "Enhance MacOS". This enables some samba features which should amongst other things improve SMB directory listing performance.
Message 2 of 5
DietmarL
Thanks!
316:
Firmware 6.9.2
Services: SMB, AFP, NFS, FTP, iTumes, ReadyDLNA, UPnP, HTTP, HTTPS, Virus protection, File search
Apps: Milestone Acru Surv., Resilio Sync
Protocol which MAC: mainly SMB but also AFP (is not faster)
NVX Pioneer
Firmware 4.2.31
Services: CIFS, AFP, HTTP, HTTPS, Bonjour, UPnP
Apps: none
I enabled the "Enhance MacOS", which seemed to have an effect on showing the directory, but still seems slower than the other!
Opening a new 2MB JPG in Finder's Viewer takes often 4-6s!
Message 3 of 5
mdgm-ntgr
If you disable anti-virus (just for testing) on the NAS how does that impact the performance?
Message 4 of 5
DietmarL
Thanks for your support, but the performance is not really better!
I recognise, that especially while I am transfering some bigger files on to the NAS, the performance including opening a folder and displaying the content is still slow (takes 30s to display the contect/directory!!!)
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 940 views
  • 0 kudos
  • 2 in conversation
Announcements
