- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 4220s not creating shares
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello! I can not create new shares on ReadyNAS 4220s, ISCSI LUNs also could not be created. When I try to add share, web interface simply restarts. In console (journalctl, dmesg) I can see readynasd daemon segfault and restart. I've installd latest FW (6.10.4 Hotfix 1) and rebooted storage - still no success.
Is there any way to fix this or maybe create resources from ssh? Any ideas?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 4220s not creating shares
Is the root partition full?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your attention!
No, none of partitions are full:
root@DATANAS:/var/log/readynasd# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 1.3G 2.4G 36% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 3.9G 11M 3.9G 1% /run
tmpfs 2.0G 1.7M 2.0G 1% /run/lock
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/md127 5.5T 172G 5.3T 4% /HyperV
/dev/md126 11T 3.7T 7.3T 34% /Datanas
/dev/md126 11T 3.7T 7.3T 34% /apps
/dev/md126 11T 3.7T 7.3T 34% /home
/dev/md126 11T 3.7T 7.3T 34% /run/nfs4/Datanas/IT
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was the root ever full? There is a script you could potentially run, but I'm not sure if if it will help. https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh
Obviously confirm that the volume isn't in read-only status first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you very much for help! This script turned out to be very useful - it have made all shares I've tried to create visible, so I have now at least one way to create new shares.
However readynasd still restarting and unable to create iSCSI LUN...
I'll try to find something useful about iSCSI in this script.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I try to create share via web UI the only thing being created is btrfs subvolume. Then readynasd faulting. In result share (subvolume) exists in filesystem, but not being exported via Samba nor showing in UI. I also tried rn_nml with same result. After applying suggested script they begin to work properly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
# btrfs fi show
- Mark as New
- Bookmark
- Subscribe
- Permalink
root@DATANAS:~# btrfs fi show Label: '7c6ecfd4:root' uuid: cc262a82-c364-4d88-8473-497b8299e134 Total devices 1 FS bytes used 1.25GiB devid 1 size 4.00GiB used 4.00GiB path /dev/md0 Label: '7c6ecfd4:HyperV' uuid: 47d1f27f-b193-4902-957b-5245665aba93 Total devices 1 FS bytes used 170.93GiB devid 1 size 5.45TiB used 221.02GiB path /dev/md127 Label: '7c6ecfd4:Datanas' uuid: b9beef89-79b7-4ed8-8149-7c894db264b6 Total devices 1 FS bytes used 3.67TiB devid 1 size 10.89TiB used 6.11TiB path /dev/md126
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! I'm not familiar enough with BTRFS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This looks like it needs some attention - perhaps a balance?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah, thanks! Live and learn... After btrfs balance /
Label: '7c6ecfd4:root' uuid: cc262a82-c364-4d88-8473-497b8299e134 Total devices 1 FS bytes used 1.23GiB devid 1 size 4.00GiB used 1.94GiB path /dev/md0
But nothing else changed, readynasd still restarting on share create
- Mark as New
- Bookmark
- Subscribe
- Permalink
What about if you do an OS Re-install?
Do you still have the problem after doing that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might be time to consider doing a full factory default and rebuild the entire thing (restoring files from backup).
Though painful, starting over would ensure a clean file system and configuration.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm pretty sure factory defaults and rebuild will solve the problem, but this is the worst case solution - to backup all data I will need to buy another one storage (
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there a way to do this and leave data intact? I don't know how it will impact on current shares.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree it's painful.
Though IMO everyone should have a backup plan in place anyway - RAID isn't enough to protect your data. So maybe consider getting USB drives to back up the NAS even if you don't choose to do the factory default.
The puzzle here is that we can't easily tell if something is wrong with the file system or if something is still wrong with the configuration on the OS. You could try doing btrfs scrubs on the data volume (maybe on the HyperV volume first), and see if that turns up anything.
You could also try paid support, they might be able to figure it out and repair it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Though IMO everyone should have a backup plan in place anyway - RAID isn't enough to protect your data. .
This ReadyNAS is our backup plan - it mainly stores backups for our servers )
Anyway thank you very much for help! I'll revert to factoy defaults when it will be possible.
