Orbi WiFi 7 RBE973
Reply
ReadyNAS 6.10.8 (RN524X) - Timeout when checking for updates
fondy
Tutor
Hi
Check for Updates from my 524X I got error:
"Cannot connect. Communicatins error. Check your internet connections, DNS Settings, or Proxy settings"
All was OK some weeks ago
PS. I see a green "internet available" indication on the cloud page
Please help
regards Paal
Message 1 of 2
Accepted Solutions
Guru
Re: ReadyNAS 6.10.8 (RN524X) - Timeout when checking for updates
This is Netgear's issue - they appear to have taken down the update server.
You should probably install at least 6.10.9 manually
If you don't use the apps page in the web, I suggest installing 6.10.10
6.10.10 is the most recent release.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 136 views
  • 0 kudos
  • 2 in conversation
Announcements
