Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo HDD replacement
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-04-04
12:10 PM
2014-04-04
12:10 PM
Hi all,
I have been using my ReadyNas Duo V2. This has been running for a while with 2 WD WD10EARS 1.0Tb drives. However one of the drives started showing a large number of errors so I have powered it down and removed the drive. As both drives were set up as Mirrored I want to replace the broken drive before I turm it back on.
I am having a problem finding the same HDD to replace with and the HCL seems to be a little outdated for the 1.0Tb drives. So I was thinking of buying one of the following WD drives:
Can anyone tell me if either of these drives will work with my current WD10EARS drive in mirror configuration?
Thanks
- WD10EZRX
- WD10EZEX
Thanks
Message 1 of 6
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-04-04
12:30 PM
2014-04-04
12:30 PM
Re: ReadyNAS Duo HDD replacement
If I were shifting off the HCL I'd get a WD10EFRX.
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-04-04
01:27 PM
2014-04-04
01:27 PM
Thanks for the info, the HDD you have suggested is only £10 more than the others so wont break the bank.
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-04-04
02:16 PM
2014-04-04
02:16 PM
It also has a 3 year warranty, while the others only have 1 year.
Abernus wrote: Thanks for the info, the HDD you have suggested is only £10 more than the others so wont break the bank.
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-05-26
07:19 AM
2014-05-26
07:19 AM
Do you happen to know if these drives you recommend also work OK in a ReadyNas Duo RND2000-100N?
thanks
thanks
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-05-26
11:32 AM
2014-05-26
11:32 AM
The WD20EFRX certainly does work, I am running one in my duo V1.
Message 6 of 6
