- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo (RND2000 v2) Drive Access
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pulled this out of the cupboard and gave it a dust down and fully reset it, to find out I can not access it using Windows 10/11 due to limitations with web browser.
how can I by pass it?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You will have to use an older browser that supports TLS1.0 to access the admin page, IE11 or an older version of Firefox might help.
Are you having errors accessing data using file explorer? You may have to enable support for SMB1
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Duo (RND2000 v2) Drive Access
Firefox v43 did the trick but can not login with default username admin
I have also tried passwords
password
admin
netgear1
Access to drives are working now after installing SMB1
- Mark as New
- Bookmark
- Subscribe
- Permalink
password
admin
netgear1
Does the NAS say
- ReadyNAS Duo on the front panel? or
- ReadyNAS Duo v2 on the front panel?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My bad, I changed the password to abc123, can now access the device.
Current firmware is 4.1.16 [1.00a043] is there a latest update available?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@claynz wrote:
ReadyNAS Duo
Ok. So you have the original Duo. That uses a sparc processor, and runs 4.1.x firmware. The v2 label just means you have hardware revision 2. This is confusing, because Netgear later released the Duo v2, which uses an Arm processor and runs 5.3.x firmware.
Your Duo is just called the v1 here - and if you google for the manuals, you will see that Netgear also now calls it the v1.
The default password for the admin account for your NAS model is netgear1. If that isn't working, then you must have set it to something else before you put it away.
You can do an OS reinstall, that will
- reset the password to netgear1
- reset the network configuration to use DHCP.
Instructions are on pages 15-16 here: https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
Be careful not to do a factory reset (which will destroy your data).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, that is the final firmware for your Duo.
Note you can adjust the NAS to allow you to use http to connect to the admin page (turning off the redirection to https). That will let you use any browser. But the connection is not encrypted. More information on that is in this thread:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Currently transferring 1.5TB of movie files around 1GB in size from my PC to NAS and only getting 15MB/s speeds, Is this normal for 1GB LAN?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No worries, I'll leave it transferring over night
- Mark as New
- Bookmark
- Subscribe
- Permalink
What size drives does this unit support? I am currently running 2x2TB as single drives
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just wanted to follow up on the sluggish transfer speed.
Many 2 TB drives are now SMR. These can have very slow write speeds - so you might want to confirm that you are using CMR drives.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes it's currently showing a C and a D volume in the web UI
- Mark as New
- Bookmark
- Subscribe
- Permalink
Currently running
WDC WD2003FZEX-00SRLA0
Seagate ST2000DL003-9VT166 (Transferring data to at the moment)
RAID Level 0, Single disk
- Mark as New
- Bookmark
- Subscribe
- Permalink
@claynz wrote:
Currently running
I believe both of these are CMR - I'm not seeing much on the Seagate, but it is an old enough model (2011) that it should predate use of SMR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, it's old and not keeping it, transferring over Movies and TV Shows and sold it to a friend for US$185
