Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo Wont Connect Via Raidar
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-20
06:58 AM
2012-05-20
06:58 AM
I have been looking through the posts and searching for a similar problem, but I am not finding a solution. I can see my Duo in Raidar, but Raidar cannot connect to it. It just times out when it attempts to connect the server address; I get two errors when I trouble shoot; one says 'check the spelling of the name of the device your connecting to' or network connection error. I have another duo which that is functioning flawlessly right next to it. Thanks for for you assistance!
Message 1 of 7
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-27
06:34 AM
2012-05-27
06:34 AM
Re: ReadyNAS Duo Wont Connect Via Raidar
Installed a new wireless router (netgear n600)and now the router is not seeing Duo; I have tried switching cables, 'pinging' it, rebooting the router. Raidar 'sees' the device, but cannot connect. Using Raidar 4.3.4....any direction or tests to run would be greatly appreciated
Message 2 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-27
08:33 AM
2012-05-27
08:33 AM
Was the Duo configured to use a static address or DHCP?
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-27
09:31 AM
2012-05-27
09:31 AM
static address; wireless is set up static also
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-27
11:59 AM
2012-05-27
11:59 AM
Ok. What IP address does RAIDar show?
Did the IP address range change with the new router?
What happens if you enter https:/nasip/admin manually in your browser address bar?
Two other things you can try: (a) a direct connect procedure, setting the PC with a manual address on the same subnet as the NAS (b) reinstalling the old router, and see if the connectivity is restored.
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-29
03:31 PM
2012-05-29
03:31 PM
192.168.11.3
Yes, the IP address range changed (i think); older router died and have not been able to resurrect.
Would you elaborate on option (a) plug ethernet cable from NAS into computer then where do I change the range of my computer's IP address?
Thanks for your help!
Message 6 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-29
03:54 PM
2012-05-29
03:54 PM
Look here: viewtopic.php?f=23&t=63545&p=356170#p356170
Message 7 of 7
