Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo wrong hard drive size deteced
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-31
01:06 AM
2015-03-31
01:06 AM
Hi, for a client that owns a ReadyNAS Duo (Sprac 4.1.14) the hard drives are not detected well.
Installed are 2x WDC WD30EFRX-68EUZN0, these are 3 TB drives. But they are detected as two hard drives of 746 GB.
Are these drives not (fully) compatible or is there a way to fix the problem?
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-31
02:43 AM
2015-03-31
02:43 AM
Re: ReadyNAS Duo wrong hard drive size deteced
This is expected. There is a known compatibility issue. The maximum capacity drives that will work with the Duo v1 are 2TB drives.
For 3TB drives you need a newer NAS.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-04-01
11:34 AM
2015-04-01
11:34 AM
Ok thanks for the answer. Is there a way to expend the current capacity of the drives to the maximum of 2 TB?
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-04-01
12:39 PM
2015-04-01
12:39 PM
You can get a higher volume if you put it on flex raid and select raid 0, there is no redundancy though.
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-04-01
03:17 PM
2015-04-01
03:17 PM
readynasuser5613 wrote: Ok thanks for the answer. Is there a way to expend the current capacity of the drives to the maximum of 2 TB?
No
Message 5 of 5
