× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Remove inactive volume to use the disk.
deiz
I decided to add more hard drives in to my RN104, a process I hoped that an X-RAID would do with ease. I already had two 1TB WD Red hard drives in it, and I added two 4TB WD Red hard drives to bays 3 and 4. Now I get this message - Remove inactive volume to use the disk. Disk#1,2,3,4, and the colour of my hard drives on the ReadyNAS are now red. Firmware is 6.6.0. It has now been Resyncing for the last 48 hrs.
I'm not an expert, and NO, I have not made a back-up. This NAS is my back-up!!!
Model: RN104|ReadyNAS 100 Series
Message 1 of 7
mdgm-ntgr
NETGEAR Employee Retired
Re: Remove inactive volume to use the disk.
The NAS is your backup if the primary copy of your data is on another device.
Redundant RAID levels such as X-RAID provide redundancy not backup.
Can you send in your logs (see the Sending Logs link in my sig)?
Message 2 of 7
deiz
Logs sent.
Message 3 of 7
deiz
How long should I expect to wait for an answer from you?
Message 4 of 7
mdgm-ntgr
Sounds like you should contact support. This looks like it could be a data recovery situation.
Message 5 of 7
deiz
Can you point me as to where I find 'support'? UK based.
What was the problems you detected from the logs?
Message 6 of 7
Guru
Start at my.netgear.com, you should be able to get a local contact after you go through the initial steps.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3484 views
  • 0 kudos
  • 3 in conversation
Announcements
