Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Which HDD for my Ultra2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-19
06:16 AM
2015-06-19
06:16 AM
Hi Guys, and Girls,
I have an RNDU2000 with 2 HHD 2TO in raid 1, i would like to uprgrade for more space, if it's possible i would like to upgrade for 2 HHD 4TO in raid1.
Any one have try this configuration? and wich HDD choose, WD40EFRX ?
Many thanks in advance, i don't find any reponse on this question on google :roll:
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-19
08:13 AM
2015-06-19
08:13 AM
Re: Which HDD for my Ultra2
freespirit wrote: I have an RNDU2000 with 2 HHD 2TO in raid 1, i would like to uprgrade for more space, if it's possible i would like to upgrade for 2 HHD 4TO in raid1.
Is your RNDU2000 set on XRAID or Flex-RAID? If its set on XRAID, then you may replace your existing 2TB disks with 4TB disks one-at-a-time but if its set on Flex-RAID, then you will have to pull-out all 2TB disk then replace it with 4TB disks then perform a factory reset for an initial setup.
Be sure to have a back up of all of your data as well.
freespirit wrote: Any one have try this configuration? and wich HDD choose, WD40EFRX ?
As per the compatibility list, only the Hitachi 7k4000 HUS724040ALE640 is the only 4TB disk listed in it. The WD40EFRX may or may not be compatible. It would be at your own risk.
You may check the compatible list of hard drives for your RNDU2000 here: http://kb.netgear.com/app/answers/detail/a_id/20641
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-19
09:33 AM
2015-06-19
09:33 AM
Its not on the HCL, but there are plenty of folks using the WD40EFRX in their ultra and pro systems. The drive will work, the only risk is that you might be denied support. I use the WD30EFRX in my pro-6.
That said, there are plenty of happy Hitachi users here also.
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-22
06:16 AM
2015-06-22
06:16 AM
Ixa wrote: Is your RNDU2000 set on XRAID or Flex-RAID?
I don't remember, where i can check this settings, i don't found it on admin interface.
Many thanks for your help 😄
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-22
06:31 AM
2015-06-22
06:31 AM
The home page of the web admin interface will tell you if you are using xraid (volume status line). https://nasname/admin or https://nasipadder/admin
Message 5 of 5
