Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Genie
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-15
02:34 PM
2012-10-15
02:34 PM
Genie
I have updated to the latest firmware V1.0.2.36_1.0.28 and cant use th e PC version of Genie as it won't let me login. I am sure I was able to do this with the previous firmware, I could change the firmware to see but I have had problems flashing the firmware in the past.
Can anyone confirm that Genie works on other firmware.
Message 1 of 9
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-15
05:21 PM
2012-10-15
05:21 PM
Re: Genie
hard reset the router after flashing firmware. test again after that
Message 2 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-16
11:01 AM
2012-10-16
11:01 AM
Re: Genie
Done hard reset, still not able to login via genie. I can login using the ip or routerlogin.net method. Is this a firmware problem or is this a problem with genie software?
Message 3 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-16
12:00 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-16
12:35 PM
2012-10-16
12:35 PM
Re: Genie
Done that, also installed ir on two of my other computers, one wired one wireless and still can't login.
Might try downgrading firmware.
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-16
01:57 PM
2012-10-16
01:57 PM
Re: Genie
dhester wrote: I have updated to the latest firmware V1.0.2.36_1.0.28 and cant use th e PC version of Genie as it won't let me login. I am sure I was able to do this with the previous firmware, I could change the firmware to see but I have had problems flashing the firmware in the past.
It works for me. Now, are you by any chance connecting via the Guest wireless SSID? And if so, do you have Enable Wireless Isolation checked? do you have Allow guest to access My Local Network checked?
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-16
02:26 PM
2012-10-16
02:26 PM
Re: Genie
I have guest turned off. This should only effect the wireless connection, I also can't login from a wired connection.
I am going to "downgrade" the firmware to see if I can use genie.
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-16
02:50 PM
2012-10-16
02:50 PM
Re: Genie
"downgraded" the firmware and genie worked, then flashed latest firmware and it now works.
I usually use the ip of the router to get access to settings so the fact that I could not use genie was not a problem, however I like to think that advertised features should work.
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-17
04:11 AM
2012-10-17
04:11 AM
Re: Genie
Glad to see you resolve youe issue.
I would have never thought that reseting and reinstalling the upgrade would have worked.
Message 9 of 9
Top Contributors
User | Count |
5 | |
4 | |
1 | |
1 | |
1 |
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
