× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
New Firmware v2.3.2.108 (XR500)
Delx
Apprentice
Re: New Firmware v2.3.2.108 (XR500)
Yes im on 114
Message 601 of 769
Netduma-Fraser
NetDuma Partner
Pre-beta or beta?
Message 602 of 769
Delx
Apprentice
not sure it was XR500-V2.3.2.114-DumaOS3.0.203
but will update now to offical release
Message 603 of 769
Netduma-Fraser
NetDuma Partner
Okay that is the right one, factory reset on that one and see how you get on. Then disable Auto Update in firmware update.
Message 604 of 769
NastySkill
Where is it I find the file for the new Beta Can you post a link for me
Message 605 of 769
NastySkill
The icon for the ping heat map is not even on the interface no more
Message 606 of 769
Netduma-Fraser
NetDuma Partner
You're on the pre-beta .114 version in that case, you can find the beta version here: https://bit.ly/39ZN5JT
Message 607 of 769
satty021
I was confused too until I went back to an older router firmware prior to the beta. .114 is an update to the original/pre-beta router firmware before Ping Heat Map and Connection Benchmark.
Apparently there is also a new beta update named similarly to .114. I can’t access that beta as the .114 I downloaded put me back to the latest original router settings prior to the beta. What is the ocorrect link to download the latest beta firmware update after .108?
Model: XR500|Nighthawk Pro Gaming Router
Message 608 of 769
Netduma-Liam
NetDuma Partner
Use this link to download the correct version (inserted link as it's ridiculously long)
Message 609 of 769
Funstuff
Apprentice
@Netduma-Fraser
Updated to 114 and factory reset. FYI 108 had been running for 42 days at time of update, so mine seemed pretty stable.
Below are two attached screenshots. The issue with updating the local IPs in device manger seemed to work except it also shows the previous ipv4.  That might be normal? I also notice the ipv6 shows up intermitently, have not seen any reason.  But if ipv6 is still not working right that might explain it. Not sure what all information it is suppose to display.
Also the network monitor screens are completey blank and do not even seem functional now.  If this issue is not just me then ignore this. I noticed this in 108 before I updated but I am not sure on my router how long those have not been working.  I know they worked in 104.
PS Should I leave ipv6 on?
Oops, can only attach one file and too lazy to combine them. Imgur one is the network monitor one.
https://imgur.com/a/nTLBaWl
Thanks
John aka Funstuff
Message 610 of 769
-JK-
Star
Does this version have ping heat map??
Message 611 of 769
Netduma-Liam
NetDuma Partner
It does indeed!
Message 612 of 769
Netduma-Liam
NetDuma Partner
@Funstuff Thanks for the update!
You could try removing the device from device manager and then reconnect, see if that clears the extra address, though I don't see it causing any harm!
Are you using IPv6 for anything? If not you can go ahead and disable it!
With regards to network monitor, can you intentionally generate some traffic like a download or something and see if it detects it?
Message 613 of 769
-JK-
Star
Cool but I can’t access share point 😞
Message 614 of 769
Delx
Apprentice
Im still seeing a lot of this in logs
[DumaOS] DHCP lease change., Wednesday, February 10, 2021 14:47:05
[DumaOS] DHCP new event., Wednesday, February 10, 2021 14:47:05
Message 615 of 769
Netduma-Fraser
NetDuma Partner
@-JK- what happens when you try to access it?
@Delx lease changes will still occur for proper functionality of the router but is it causing any disconnects?
Message 616 of 769
-JK-
Star
It says “that didn’t work”
User not in directory
Message 617 of 769
Netduma-Fraser
NetDuma Partner
Message 618 of 769
tekonsite
Apprentice
Hi @Netduma-Fraser
Like I said before, it maybe in your best interest to start a new thread about the New Firmware "v2.3.2.114-DumaOS3.0.203" (XR500)
This way you can track the bugs in this firmware v2.3.2.114-DumaOS3.0.203 BETA and not have to keep directing beta testers to the new Beta.  This is just a suggestion....
I have been using this latest beta and it is working well in terms of the Ping Heatmap and the DHCP issues look to be fixed.
Still lots of bugs to squash but off to a good start.
Message 619 of 769
Delx
Apprentice
Yes thats the beta firmware I was using. I now downloaded 114 firmware from XR500 Firmware Version 2.3.2.114 | Answer | NETGEAR Support and reset.
which is the best?
Message 620 of 769
niewiado
Apprentice
@Netduma-Fraser the link you posted to the new beta .114 prompts me for a Microsoft account password that I can’t seem to get past. Should that be the netduma account password or the netgear one?
Message 621 of 769
Netduma-Fraser
NetDuma Partner
@tekonsite I would do that but we haven't officially released it yet really, I'll talk with the team though as it's basically released now.
@Delx the link you provided there is the non beta version so it depends whether you want to continue using the beta or not.
@niewiado use the dropbox link above and it shouldn't ask you for a password.
Message 622 of 769
-JK-
Star
Done.
All seems to working Sweet
Thankyou All
Message 623 of 769
Funstuff
Apprentice
@Netduma-Liam
I am unable to remove the device from the device manager which seems to be another bug. The delete is faded out on the device I am trying to delete. See attached file. I tried from 2 different PCs and also unplugged the device I was trying to delete from the XR500 router with no change and in the time (a few minutes) it never went to an offline state. The devices showing offline did have the delete highlighted.
Also below is the image link for a download going with not information relayed to the network monitor app.
https://imgur.com/BYP1wWg
I disabled ipv6 for now.
Thanks.
John aka Funstuff
Message 624 of 769
Netduma-Liam
NetDuma Partner
The device needs to be offline in order for you to delete it from device manager, sorry I should've been clearer.
Have you tried rebooting the router just to see if network monitor then recovers?
Message 625 of 769
Top Contributors
Announcements
Orbi 770 Series
