Orbi WiFi 7 RBE973
New Firmware v2.3.2.108 (XR500)
ivanrei
Star
Re: New Firmware v2.3.2.108 (XR500)
Hi @Netduma-Fraser,
What speeds are you getting through the router using speedtest.net for example?
  • I'm getting my ISP speeds 250/20 on both wired and wireless.
Is it only wireless devices or wired as well?
  • Both. PS5 and note are wired.
The Geo-Filter can cause a misreading of NAT on the game but it will actually be open - what did the console network settings say for NAT?
  • PS5: Open - COD BOCW: Moderate. If I add port forwarding I get Open in game as well.
Thanks.
Model: XR500|Nighthawk Pro Gaming Router
Message 651 of 769
Netduma-Fraser
NetDuma Partner
@namsayin that's right, the official XR500 support page with downloads are all pre-beta firmware.
@ivanrei Interesting, are you using custom DNS or the one provided by your ISP? If that works for you then that's great, I would try disabling the Geo-Filter at some point without them and see if it changes to open.
Message 652 of 769
ivanrei
Star
@Netduma-Fraser
I'll give that a try for the NAT type.
What do you think I should do about the other problem, Go back to 108?
As I'm basically not even using my home network for browsing and E-mailing because of this problem,
Thanks.
Message 653 of 769
Netduma-Fraser
NetDuma Partner
@ivanrei I would suggest changing the DNS - your speeds are fine so it might be the specific DNS you're using is having trouble resolving the hostnames.
Message 654 of 769
Hi to all!
There is a new beta for the XR500???? Why there is no a new top about this?? how can i download it? is stable??
Best regards!!!
Message 655 of 769
Netduma-Fraser
NetDuma Partner
@KostasKtm83 It's not been officially released but was given to potentially solve the DHCP issues. You can find it here: https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0 from reports so far it is quite stable. Recommend factory reset after upgrade as usual.
Message 656 of 769
Funstuff
Apprentice
@Netduma-Fraser
The devices I have been using and testing are all wired so far, if that makes any difference.  I have not played with wireless at all yet.
Message 657 of 769
MattyAu
Guide
Any idea how far off another Beta (or offical) release is? Trying to decide whether or not it's worth installing .114, as it's a PITA having to factory reset.
Message 658 of 769
steiNetti
Tutor
Is the 2.3.2.114 officially out yet?! My XR500 just auto-updated to it..
UptimeRouter TimeBoard ModelFirmware VersionDumaOS Name
09:43:18 up 7 min, load average: 4.94, 3.99, 2.06
Thu Feb 18 09:43:18 UTC 2021
NETGEAR XR500
V2.3.2.114
A7Legit
PS: I never manually installed any DumaOS 3.0 beta..
Message 659 of 769
Netduma-Liam
NetDuma Partner
We don't have an ETA for the full release yet, but the beta version are getting better and better so hopefully it won't be too far in the future!
Message 660 of 769
Netduma-Liam
NetDuma Partner
That's a pre-beta verison, unfortuantely it shares the .114 version number which has created some confusion!
Message 661 of 769
Arthurr
Hi, I just bought the XR500 one month ago and it really disappointing to have this kind of issues, I have my ps5 connected trough lan port and every time I turned on I have the same problem, 6 or more lan disconnections that occur one after one, the logs only show "DHCP lease", I have try everything I saw in this and other post that surprisingly came from 2018 to this date and nothing works, I'm currently using the.114 beta version that I install via tftp make the factory reset and still got the problem, any news on this fix??
Message 662 of 769
Netduma-Fraser
NetDuma Partner
@Arthurr is this the LAN cable disconnected message? I don't think that is specifically a router problem, do you just get disconnects on that device?
Message 663 of 769
satty021
I know this is a beta forum and typically responses related to issues. I just wanted to say .114 is stable for me and I’m enjoying the enhanced traffic rules/prioritization and assigning those at a device level. I use MS Teams and other apps often for work while kids are streaming and that helps avoid drops or other bandwidth issues; especially living in an area where I can only get DSL and upload speed is minimal. Thanks for your work on this!
Message 664 of 769
Netduma-Fraser
NetDuma Partner
@satty021 that is fantastic to hear, thank you for sharing your experience with us! It's great to hear the good things as well 🙂
Message 665 of 769
MattyAu
Guide
Any reason I get a monster ping at the start of the Ping Test. Happens every test regardless of QoS settings.
Message 666 of 769
Netduma-Fraser
NetDuma Partner
@MattyAu that is an anomaly, you can ignore that - we're looking into it.
Message 667 of 769
Funstuff
Apprentice
@Netduma-Fraser  @Netduma-Liam
This has a couple issues to address.
Well my router finally did reboot on it's own. The first time I know of. since I have owned it (April 2018). In the process of trying to send me and forward the logs I had issues getting the settings and log e-mail to work. As far as I know I had set up correctly and tried two different e-mails. One was a yahoo account and the other was my ISP e-mail account. I did notice that after entering my e-mail password (if it is needed) and hitting apply it would blank out the password field. No idea if that is normal since I never tried to set it up before.
Would love some help trying to get it to work though if time or anyone else in here has it working.
I went ahead and copied and pasted the log to a file and it is attached. It should contain from the reboot until I stopped with the e-mails.
Two questions I have for anyone who might know. Does the log clear on a reboot and is it suppose to? Mine was, seems strange to not keep that info.
Secondly and this drives me nuts. Is there a way to legthen the in-activity timeout for the router login or am I just missing it?
Thanks,
John aka Funstuff
Message 668 of 769
Netduma-Fraser
NetDuma Partner
Unfortunately the log does clear upon a reboot so that won't have anything useful within it. If this is the first time it has happened in almost 3 years then hopefully it's nothing concerning and just a blip. If it happens again try to figure out what was happening on the network at the time.
Message 669 of 769
Xolhid
Apprentice
Would you please separate these settings? My roomate and I have our own cast devices. I have him set up on the guest network while i use the main network. I do not want to see his cast devices on my network and vice versa. Disabling this option prevents him from casting to his own devices. 2 separate options would be nice
1. Allow guests to see each other
2. Allow guests to access my local network.
Whatever needs to be done so he can't see my devices and i can't see his. Google doesn't have a way to do this. I have already looked. I'm sure I'm not the only only person who wants this. Thanks
Message 670 of 769
Netduma-Fraser
NetDuma Partner
I'll pass that onto NG @Xolhid
Message 671 of 769
Raf1212
Apprentice
hello I hope that you are healthy, will there be any version with repaired qos and corrections, because there was no version other than 114DHCP for a long time, I saw that other platforms received newer versions
Message 672 of 769
Netduma-Liam
NetDuma Partner
What issue are you currently experiencing with QoS? Of course any bugs found during these beta firmware's are being worked on and will be resolved before a full release!
Message 673 of 769
Raf1212
Apprentice
@Netduma-Liam sorry but you are probably not up to date, and that's not good, a few posts above we wrote that the factory reset does not clean the qos memory, and it works incorrectly,
Message 674 of 769
Netduma-Liam
NetDuma Partner
Apologies, both myself and the team are aware of that issue, it's being worked on diligently
Message 675 of 769
Top Contributors
Announcements
Orbi 770 Series
